Hey I was wondering if a 302 Y pipe would work on a 351w. The Y pipe is for a 1985-1995 302 in a bronco up to a f-250 and the truck it needs to go on is a 1994 f-250 with a 351w.
It's not a direct fit, its a little too narrow at the motor and it won't match the factory cat back connection in an F250.... but it could be modified to fit by someone with a welder.
Summit / jegs or a walker exhaust dealer will have an OE replacement y pipe for the f250 351w.
trucks with an E4OD will use part number 40585
Trucks with manual trans use part number 40572
verify part numbers and application.
bassani offers an f150 5.8 piece but its not cheap and it may not be a direct replacement for the f250.
Youd probably be better off just going to an exhaust shop and have them make one. They can do it easily.
The bassani for gen 1 lightnings is available. Its a dual pipe Y with a crossover, unlike your bassani single out, "offroad" offering, neither are a bolt in deal for f250s, the exit flange orientation, is different.
All will bolt to stock manifolds, stock gen 1 headers, aftermarket shorty headers.
