Alternator pulley
Old Feb 7, 2017 | 07:29 AM
Gary Lewis's Avatar
Gary Lewis
My first thought - Serpentine, serpentine!
And on second thought, if you figure out how to have two sets of dual belts please let me know. Big Blue could use them as he has the one set of dual belts running the water pump and power steering pump as yours, and needs his 1G replaced by a 3G.
Old Feb 7, 2017 | 07:36 AM
Toddster's Avatar
Toddster
So I found one on summit's website for $20 shipped. Hope it will work should find out tomorrow.
Old Feb 7, 2017 | 07:42 AM
Gary Lewis's Avatar
Gary Lewis
Make sure both sheaves are the size you need. All of the ones I found used different sized belts.
Old Feb 7, 2017 | 07:44 AM
Toddster's Avatar
Toddster
https://m.summitracing.com/parts/tff-7610f That's the one I ordered
Old Feb 7, 2017 | 07:45 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I thought Big Blue had a one wire Chevy alternator???
Going serpentine could be a challenge as fuel injected 460's (with the serpentine belt) have different head and waterpump bosses.
I use one belt and the L&L alternator bracket with my 3G.
My truck doesn't have a bunch of high current accessories.
Old Feb 7, 2017 | 08:05 AM
Gary Lewis's Avatar
Gary Lewis
Todd - It doesn't say what belt size each sheave takes. Hopefully they are the same and the size you need.
Jim - Big Blue had a 1-wire Chevy alternator. It died and Powermaster said "We don't sell parts - ship it in and we will rebuild it." So, having a 1G on the shelf and seeing a regulator and familiar wiring on the fender, I bolted it in and hooked it up. Works perfectly and it can be replaced at about any parts store known to man. However, when I install a winch and a second battery it won't even come close to providing enough power, so a 3G conversion will happen some day.
Old Feb 12, 2017 | 08:01 AM
Toddster's Avatar
Toddster
Just to give you guys an update, I'm glad to say the pulley worked
Old Feb 12, 2017 | 08:34 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Hey, that's great!
Do you have a pic of your completed installation?
​​​​​​​What belts did you end up using?
Old Feb 12, 2017 | 12:49 PM
Toddster's Avatar
Toddster
I can get you guys a pic later. I am going to replace the alternator on Monday cause the bearing squealing. I just used the oe belts.
Old Mar 25, 2017 | 11:41 AM
Toddster's Avatar
Toddster
Originally Posted by ArdWrknTrk
Hey, that's great!
i used stock belts. Sorry I didn't respond sooner.
Old Mar 25, 2017 | 02:45 PM
kh0432's Avatar
kh0432
Look for an alternator / starter rebuild shop in your area. They should be able to match a pulley for you.
Old Mar 25, 2017 | 05:07 PM
FuzzFace2's Avatar
FuzzFace2
So now seeing a picture why did you need the duel pulley as I only see 1 belt on the ALT and looks to have a belt, P/S?, in the other groove the ALT would use.
Dave ----
Old Mar 25, 2017 | 10:43 PM
  #28
Toddster's Avatar
Toddster
Dave ----
i was just trying to get close to stock as possible and honestly at the time I didn't know much about these engines. The alternator was the first thing I replaced
Old Mar 26, 2017 | 06:47 AM
  #29
FuzzFace2's Avatar
FuzzFace2
Ok got it.
I think someone put a different ALT on that had that pulley or the stock pulley had a smaller ? dia outer pulley to drive the air pump that should be mounted above the ALT.
My truck has been so jacked up by other people I cant tell what it should have stock or not. Different year (car?) motor and the ALT pulley is only for 1 belt. Don't have an air pump so I am good with what it has.
I do plan on a 3G swap when I need to put the ALT back on the motor as the truck is going thru a rebuild.
Dave ----
Old Mar 26, 2017 | 08:30 AM
  #30
Toddster's Avatar
Toddster
Ok got it.
Dave ----
dude I know exactly what you mean. I am still going through the electrical nightmare
