quick question
Old Feb 5, 2017 | 05:43 PM
mario9272's Avatar
mario9272
quick question
Good Day Everyone.
Just a quick question. i am in the process of putting new gears in my truck. swapped out gears in the front diff. and know i am putting everything back together. Does anyone know the torque specs on the hubs ?
I want to put a transmission cooler in after the rad. but i am not to sure which line is the return line.
The truck is a F250 HD 1986
Thanks Mario
Old Feb 5, 2017 | 07:58 PM
Franklin2's Avatar
Franklin2
What hubs are you talking about? The little allen head screws that hold the chrome piece on? Or the little lug nuts that hold the spindle in place?
When I put my cooler on it had instructions that told me from dead cold, start the engine and run it for a minute and then shut it off. Then feel the tranny lines at the transmission, the warmer one is going into the radiator, the cooler one is going back to the trans. It works.
Old Feb 7, 2017 | 07:22 PM
mario9272's Avatar
mario9272
I am talking about the torque for the wheels bearing. I have everything apart and can do seem to find what to torque the wheel bearing up too.
Old Feb 8, 2017 | 07:59 PM
Franklin2's Avatar
Franklin2
Is it 2wd or 4x4?
Old Feb 8, 2017 | 10:26 PM
mario9272's Avatar
mario9272
It is a 4x4.
Old Feb 9, 2017 | 06:35 AM
Franklin2's Avatar
Franklin2
If you have the clicker type nut, tighten it to 25 ftlbs. If you have the dual spanner nuts, tighten the first nut to 25 ftlbs, put the lock washer in the place on the pin. If the pin won't go, back the first nut up till the pin goes in one of the holes, then put the second spanner nut in place and tighten it against the locking washer to 150 ftlbs.
Old Feb 10, 2017 | 09:03 PM
mario9272's Avatar
mario9272
Thank you Franklin2
brennanforgeron
15
Nov 14, 2016 10:31 PM
Volcom
Aug 1, 2015 07:24 PM
Warhippie
Jun 14, 2009 07:12 AM
LongJim
May 11, 2007 08:12 PM
HerkFE
Nov 2, 2003 06:12 AM
