I have an '87 bronco w/the 5 bolt auto lock hubs. I want to convert them to manual locks (warn) and am a bit confused. I went to NAPA to get the hubs and they said that I also need a conversion kit. I inquired as to why I need it and they didn't really know. I personally don't know jack about how auto locks work but I do need to know: Do I need a conversion kit w/5 bolt auto locks or can I just switch the hubs? Thanx
Since I seem to be getting conflicting information I guess I will go with the majority and what I found searching on this topic, which is 5 bolt auto locks can be directly replaced with manual hubs w/no conversion "kit". If its wrong, I guess I will find out when they are apart. Thanx for the replies.
with 5 bolt hub caps you do not need the conversion kit. i changed mine to warn standards in about 30 minutes a side. they only cost 70.00 dollars but i would use the premiums if i were to do it again. they have brass twist ***** instead of the plastic ones.
Gene, I to have this problem with the inner c-clip. How did you manage to get it on and what is the tool for making this easier?
geneb11
View User's Gallery That inner C-clip is a bitch. I used 2 screwdrivers. They have a tool for that. All in All it's an easy swap.
use dental pick type tools avail at wally mart, etc...or try the small flat bladed screwdrivers top get it off and install.
ck my site for pics by yoher bronco owners on this
