F150 4x4 conversion
Old Feb 4, 2017 | 04:23 PM
Evans88's Avatar
Evans88
F150 4x4 conversion
Hey all
I have a 1989 f150 custom 300, 2wd with a clean body and interior that I'd like to convert to 4x4.
I know the easiest way to do this is finding another f150 and I plan on doing so but I do have a 94 f250 ttb 4x4. Before I go on my way finding a donor f150 is it possible to use my existing f250 without using the front leafs? Or are all the mounts different and not worth the effort?
Old Feb 4, 2017 | 04:34 PM
rj1983's Avatar
rj1983
good question, would be interested in finding out about that myself. Always wished Id bought a 4x4 but mine was in too good condition to turn down.
Old Feb 4, 2017 | 04:35 PM
Evans88's Avatar
Evans88
That's the boat I'm in.
Old Feb 4, 2017 | 08:04 PM
Briansshop's Avatar
Briansshop
Because of the leaf springs, the 250 doesn't have radius arms, so you'd need them from a 150. Not sure if they would mate up to the 250 TTBs. How about using the 250 stuff,springs and all?
Old Feb 4, 2017 | 08:28 PM
Evans88's Avatar
Evans88
The problem I have with using the 250 springs is they're already tired from carrying a 7.3 plus I'd end up spending even more time fabricating mounts for leaf sprigs on the f150. So no use in trying to fit f250 running gear in the f150 without lots of fabrication time is the consensus?
Old Feb 5, 2017 | 05:43 AM
BWD444's Avatar
BWD444
4X4
If you are going to do the work of converting I would use a solid axle and ditch the IFS
Old Feb 5, 2017 | 05:55 AM
SteelHorse4x4's Avatar
SteelHorse4x4
I ditched the ifs and couldn't be happier.
Old Feb 5, 2017 | 09:16 AM
78 PEB's Avatar
78 PEB
Nice truck......What is the front bumper with the fog light off of?????
Old Feb 5, 2017 | 10:22 AM
SteelHorse4x4
00a0a da8kA8rRBxY 600x450
LOL about the bumper. It was on the truck 3 yrs ago when I bought it. I've looked high and low for one like it. I've only seen 1 other looking numerous times on google. I love the fog lights and really want to do a winch, I have 2 brand new Mile Marker 10500 lb winches, but I cant bring myself to cut that bumper up until I find another like it. This is the truck the day I bought it for 1700.00.
Old Feb 5, 2017 | 10:48 AM
ng19delta's Avatar
ng19delta
My plan changed- I am looking into eventually buying the 4wd frame & running gear, and transferring my engine, trans, body, etc over to the frame after I clean and restore it... Only way I can afford one is the rock soup method...
I DO have an IFS axle on hand already, but just haven't had the motivation to install it yet- and I understand the 2wd frame is NOT as structurally strong as the 4wd frame. Or am I incorrect in this?
Scott
Scott
Old Feb 5, 2017 | 11:19 AM
Conanski's Avatar
Conanski
For a 1/2 ton there is no difference in the frames, but the easiest way to do this swap would be to transfer your body onto a complete 4wd rolling chassis. Remember not only do you need the axles but a 4wd trans + t-case and the driveshafts.
Old Feb 5, 2017 | 11:55 AM
SteelHorse4x4
Definitely agree with Paul. That way you can get the frame all cleaned up and restored while you're driving your truck. WIN WIN.
Old Feb 5, 2017 | 08:39 PM
ng19delta's Avatar
ng19delta
No difference between the frames on the half ton? Might just go after the transfer case then...
Although I do like the swapping over idea, but if the frame is the same, I can do it quicker...
Thanks!
|Scott
Old Feb 5, 2017 | 10:30 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Did you use a find/use a kit for the conversion or did you fabricate a kit?
1970f250boy
Feb 6, 2012 10:41 PM
81fordtruck
Dec 18, 2003 04:35 PM
TheBigBadWolf
Sep 2, 2003 01:09 AM
pjern
Offroad & 4x4
Jun 20, 2001 04:31 PM
