Gas mileage and gear ratios
on
That exhaust work will still flow much better than stock if you use mendrel bent tubing so you will see lots more HP too. Also note that as indicated above the SD system generally runs leaner than MAF so the exhaust should deliver the mpg gains without a MAF swap.
Oh, I was gonna do an exhaust anyway. I get crush bent tubing at the local muffler shop. What size pipe should I get to make up for the slight loss through crush bending?
They do use a hydraulic bender I believe. It has a curved end the pipe fits against and as its pushed against the curved part, it bends. Does that sound like a hydraulic bender?
https://m.youtube.com/watch?v=p04NPv_gXsI
Watch this vids on how to pull codes, the check them. Also I may get flack for this, but I would do a trans swap instead of a gear swap. Go for the overdrive and that way you don't loose the lower around town driving hear ratio
gonetruckin
04-23-2006 08:46 PM
fordtruckin
04-04-2003 04:41 AM
