Distributor harness
Old Feb 4, 2017 | 08:28 AM
DisneysPatB's Avatar
DisneysPatB
Distributor harness
I have a 1970 F250 Camper Special 390. The wire harness is fried, the PO had made many modifications to it. I have yet to have it running due to said fried harness. Wires to the coil and starter relay were melted as well as under dash. I have pulled out the harness and replaced it with a clean uncut harness from a 72. My only issue at this point is the pigtail. Yes I can just wire this in, but I only want to do this as a last resort. Where can I find this part. I went to the Pick Your Part here in Sun Valley yesterday, but pre 80's vehicles apparently are a thing of the past. Best I can figure is this goes to the oil pressure, the temp sending and to the coil and distributor. Other than this, this harness has been a breeze installing. I will have to modify it slightly to hook up the fuel gauge selector switch, this is one of the things the PO removed. I have a stock switch to install soon. The distributor has a Pertronics ignition in the distributor so there will be a slight modification there. Any help is greatly appreciated. Also any LA guys who would like to show off their truck, I would love to see them, more helpful than wiring schematics
Ford Truck Picture by DisneysPatB | 6960268 | Ford-Trucks.com
Ford Truck Picture by DisneysPatB | 6960270 | Ford-Trucks.com
Old Feb 5, 2017 | 01:42 AM
GaryKip's Avatar
GaryKip
So do you want a wiring diagram or the pigtail connector (part number)?
Old Feb 5, 2017 | 02:11 AM
DisneysPatB
I have plenty if diagrams. I need the actual pigtail.
Old Feb 6, 2017 | 06:35 AM
GaryKip's Avatar
GaryKip
Snowing rather heavy right now, I'll try to go out around noon and look at mine.
Old Feb 6, 2017 | 09:57 AM
DisneysPatB
Thanks but I found one on Mustangsunlimited.com
DaizeeDoesIt
19
Apr 26, 2018 06:45 PM
dthut
27
Jan 4, 2017 10:25 PM
DutchmanAZ
Electrical Systems/Wiring
Jan 8, 2002 09:15 AM
ecarter50
Jan 7, 2002 01:32 PM
rick
Mar 26, 2000 09:00 PM
