New 10 Speed...
My biggest complaint is for around town driving. If left in standard mode (not Tow/Haul or Sport mode) it NEVER uses 2nd gear. On cold mornings or starting from a stop up a grade, the engine bogs on the 1 to 3 shift. It will also skip 5th. If accelerating gradually on city streets, the first 30 to 40 percent of accelerator pedal travel feels like stepping into a bucket of mashed potatoes since there is no turbo boost. If you mash it then acceleration is brisk. Sometimes that 1-3 shift can be accompanied by a pronounced clunk. You're in 10th gear by 40 mph so any attempt to accelerate will cause a downshift to 7th or 6th gear.
You could ride around in Sport mode in which case ALL gears are used and each is held longer but you won't get above 6th gear unless you're over 60 mph and it pounds your fuel mileage. But, put it in Sport mode and enable Advanced Sport Trac Mode and it does haul A** and will melt the rear tires in 2WD.
I will learn to live with it but having had an '14 Explorer Sport with the six speed and immediate turbo boost it takes a bit getting used to it.
My wife's 2017 CR-V has a 1.5T with a CVT and I'm a convert when it comes to more speeds paired to a turbo. Its the best of all worlds when you always have power on tap regardless of the operating conditions.
The 10 speed has three modes. Normal, Tow / Haul and Sport.
In Normal mode, it NEVER uses 2nd gear and rarely uses 4th. On cold mornings or when accelerating from a stop on a hill that first to third jump tends to bog the engine unless you're ready for it with a heavy right foot.
The top 3 gears are overdrives and you're in 10th by 40 mph. There's a lot of shifting in the 6, 7, 8, 9,10 ranges in light city traffic. In addition, the first one third or so of throttle travel does not bring on any boost so it sort of feels like stepping into a bucket of mashed potatoes. Lean on it, make it downshift and make boost and it will impress.
Both Tow / Haul and Sport mode delay up-shifts considerably, use all 10 gears and bring on the boost early. You'll rarely see greater than 6th gear in city driving and won't see 10th until about 65. The main difference between Tow / Haul and Sport that I can see is that Tow / Haul provides considerably more engine braking. Either one will produce excitement from a standing start. You'll get to test out Traction Control (or you could just disable it and have some fun). Both take a big toll on fuel mileage.
Don't get me wrong, I really like the 10 speed and most of my driving is done in Normal mode. I just takes a bit of getting used to.
Oh yea, I'm also getting 22 mpg on the highway in an F150 with 3.55's. My Explorer Sport with the Gen1 engine and 6 speed never got that.
Here is a good article on the new 10 speed slushbox
Car and Driver
great post , good job explaining it
The closer the gear spacing, the less heat that is generated during shifts and the closer the engine can be kept to it's effective (and efficient) torque curve..
It will be a BOON to those that are towing!
