In the dark
Old Feb 3, 2017 | 12:34 AM
Karlow's Avatar
Karlow
In the dark
I have had the PSD about 2 months. It's a 2000 Ext cab LXT.
If you open the door, no lights. If the key is in the ignition and you open the door it buzzes. If you have the light on, the light around the door locks and window controls stay on after you turn off the truck until you open the door. The dome light never comes on unless you use the switch on the light. What's up with the darkness! This truck is like a cave! No under dash lights, no door lights no dome light! As for those red lenses on the door, no wiring, no lights no nada! Do the lights com on when you open the door? Any light?
Old Feb 3, 2017 | 07:16 AM
Walleye Hunter's Avatar
Walleye Hunter
Dome light and load light (the light on the back of the cab) should come on when you open the door. I never checked to see if there are any under the dash lights. They remain lit for about 30 seconds after you close the door. The radio and windows should still work after you shut the truck off until you open the door. I don't think that my truck has lights around the window and lock switches. Door lights under those lenses come into play on later models but I don't know when.
Old Feb 3, 2017 | 12:02 PM
Karlow's Avatar
Karlow
Can anyone help me out with a wiring diagram? You might not notice the light on the door because your dome light works! That door light outlines the door controls. you will notice when running at night. It tied into the dash lights. There is a shell on my truck, it might be covering the load light. I will check the windows and the radio tonight. It might be instructive. Thanks guys.
FloridaFordGirl
Apr 30, 2011 11:53 AM
oldfordisbetter
Jan 6, 2011 08:29 PM
Glenn Graham
2004 - 2008 F150
Jun 1, 2009 10:20 PM
jasonschwenk
Nov 21, 2006 06:58 PM
TheBigF
1997 - 2003 F150
Oct 15, 2005 12:09 AM
