center console lid
Old Aug 28, 2003 | 03:32 PM
DaveW396's Avatar
DaveW396
center console lid
Anyone know of a source for replacement center console lids for the console storage unit? Mine (which I use as an arm rest) has the covering all cracked.
DaveW
Old Aug 28, 2003 | 06:56 PM
HomerWinzlow's Avatar
HomerWinzlow
center console lid
You can still find quite a few from the dealer, or check your local salvage yards. Or you can go to an auto upholstery place and get it recovered.
Old Aug 29, 2003 | 03:50 AM
marragtop's Avatar
marragtop
center console lid
You can also check ebay. Do a search on 'ford explorer console'. Not sure what year/color you need, but it's worth a try.
Old Aug 30, 2003 | 11:33 PM
CobraXP's Avatar
CobraXP
center console lid
Mine cracked a while back. I went by an upholstery shop and bought a piece of vinyl that matched for $5 and did it myself. All you need is a good stapler and some 3M adhesive spray glue (about $5 a can). It is not a hard job at all. Just unbolt the lid, then remove the bottom piece of plastic, and fit the new piece on and staple in place...
Old Sep 4, 2003 | 08:56 PM
DaveW396's Avatar
DaveW396
center console lid
Thanks CobraXP. You don't have any pictures do you? I know it sounds like a simple fix. Just wondering.
DaveW
Old Sep 5, 2003 | 09:13 AM
CobraXP's Avatar
CobraXP
center console lid
My X is 2000 miles away right now, so I can't get a good pic for you to see, but hopefully you can see it well enough in this pic to see it matches perfectly.
One thing to add - unless you have an air stapler, or a mechanical that can stand a lot of pressure, you may want to just take the lid off and take it by an upholstery shop and have them staple it. You have to go through the material and a layer of plastic on the lid. Most hand staplers won't penetrate the plastic. You can also use small tacks and a hammer if need be...
Old Sep 5, 2003 | 09:18 AM
DaveW396's Avatar
DaveW396
center console lid
Thanks for posting the picture. Looks nice. And for the advice about the stapler. Never have enough tools
DaveW
Old Sep 8, 2003 | 12:34 PM
donnak5472's Avatar
donnak5472
center console lid
Thank you. Thank you. Thank you! I just joined and found several of you with the same problem. I'm going with the fix-it-yourself route as I do with just about everything!
Thanks for a great site!!!
