Building an F350
Old Feb 2, 2017 | 10:15 AM
BuickBrian's Avatar
BuickBrian
Building an F350
I have a question, but first the background: I am building a truck out of 3 trucks. Chassis is from an 87 F350 4x4 SRW that had a blown engine and trashed/rusted body. The body and transmission are an 89 F150 4x4 that had the optional granny 4-speed trans. Engine is a 8.8 I got from the junkyard out of a 91 F350 dually that was an automatic. Got the correct flywheel/clutch/pressure plate off another truck at the same junkyard.
My question is, does anyone have an 89-91 truck with the 5.8 and manual trans that they can post the EEC IV calibration code from? I need an ECM for this truck and am finding nothing but confusion looking on Ebay and at the in-complete lists of calibration codes I can find on the web. Oh, and the F150 that the body and trans came from was a 302, so I can't use the computer from it.
I have the truck up and running with a computer from a bronco that had a 5.8 and E4OD, but it of course has check engine light all the time due to not having an E4OD connected to it. Here is a pic of the truck as of this week so you can see what I am doing.
Name:  assembled truck.jpg
Old Feb 2, 2017 | 11:13 AM
rla2005's Avatar
rla2005
E9TZ-AEB Listed as a PCM for a 1990 F150/250/350 w/5.8L engine and manual transmission. Also fits other years.
Old Feb 2, 2017 | 12:34 PM
BuickBrian's Avatar
BuickBrian
How do I translate that to the code that is printed on the tag on the side of the ECU connector? Here is a pic of one on Ebay right now that I think may be fore a manual transmission, but want to confirm before I buy it. This one has code E9D on it:
Old Feb 2, 2017 | 12:55 PM
rla2005's Avatar
rla2005
I typically suggest to leave out the 12A650 because all PCMs use that as part of the base part number.
You can use search strings E9TF-AEB or E9TZ-AEB. One of the prefixes is the part number the other is the engineering number ( or something like that).
Unless you are looking for a Mustang based A9L or a more common catch code (BIO0) your best best are one of the numbers I listed above.
Old Feb 2, 2017 | 02:00 PM
BuickBrian's Avatar
BuickBrian
The one I posted the pic of says AE1A--does your list show that is for a manual trans? The seller is claiming it is and it is a really good price on it.
I found one on Ebay that has AEB, but it is twice the price and someone has written on it with a marker that it came out of a 1990 F250 4x4 ATA. The ATA makes me suspicious it was an auto transmission.
Old Feb 2, 2017 | 04:44 PM
rla2005's Avatar
rla2005
E9TF-AE1A should work fine. An old post of mine shows that was for a 1991 F-series with a 5.8Lengine and manual transmission. That will work in your application to the best of my knowledge.
Whatever you do once you get the PCM open it up and look for signs of leaking capacitors. A very common issue these days. As a preventive measure I would replace them once you verify it works as-is.
Old Feb 3, 2017 | 06:52 AM
BuickBrian's Avatar
BuickBrian
I ordered that one last night. 88-91 all have the same sensors and functionality on the system, so they are interchangeable. I do think there were improvements to the calibration over the years though because on other trucks of this vintage I have built, engines I have put the 90 and 91 ECUs on run much better and have better driveablity than the 88-89 ECUs.
What are the symptoms of leaking capacitors in the EEC IV? I was not aware of that issue with the EEC IV. I am skilled at electronic repair, so changing them does not scare me, but if I do it, where is a good source for the replacement caps? Is it just the large ones that are of concern and not the smaller ceramic-disc caps?
Old Feb 3, 2017 | 07:16 AM
rla2005's Avatar
rla2005
The electrolytic capacitors are well known to leak these days. Age is getting to them.
Good example of this:
Any good electronics supply will have or can order the capacitors. There are a few threads in recent past about the issue and vendors.
BuickBrian
Oct 7, 2012 07:02 PM
Piece of Kake
Oct 8, 2009 04:45 PM
kools20
Bronco II
Jun 1, 2009 11:32 AM
blanes
18
Dec 9, 2007 03:35 AM
Jerry74explorer
Jun 16, 2002 01:08 AM
