bps code??
Old Feb 3, 2017 | 09:08 PM
  #31
madpogue's Avatar
madpogue
Originally Posted by Shawn MacAnanny
did you drill the fitting in the manifold? My Fitting in the manifold was clogged
This is what happened on one of our trucks.
Old Feb 3, 2017 | 10:36 PM
  #32
oldbird1965's Avatar
oldbird1965
I cleaned my tube but never checked that
Edit: I don't mean that tube!
Old Feb 4, 2017 | 07:02 AM
  #33
knottyrope's Avatar
knottyrope
did you check to see if the sensor was clogged?
I rammed a coat hanger rod in the hole to make sure the exhaust would come through. It was tight but I got it done.
Old Feb 4, 2017 | 08:27 AM
  #34
oldbird1965
Its a new sensor but I'm going to have to check the manifold.
Old Feb 4, 2017 | 09:54 AM
  #35
Jarrett Campbell's Avatar
Jarrett Campbell
Since the pressure is changing, wouldn't that indicate that the passage is clear (or clear enough to allow air flow)? I think I have a bad sensor.
Old Feb 4, 2017 | 10:16 AM
  #36
madpogue's Avatar
madpogue
I had that ^^^^ same thought, if the sensor is responding, the passage is obviously not completely plugged. This is a reach, and complete speculation, but MAYBE it's partly restricted, right at the manifold fitting as Shawn described, and the restriction is causing the pressure to read higher (smaller opening == higher pressure maybe?).
Old Feb 4, 2017 | 10:39 AM
  #37
Jarrett Campbell
I don't think that is the case since it reads more pressure than it should when the truck is not running (even though the same concept did cross my mind)
Also, a restriction wouldn't cause more pressure, it would cause more velocity.... or less volume.
Old Feb 4, 2017 | 10:42 AM
  #38
madpogue's Avatar
madpogue
Well I know when mine was completely clogged, the sensor read higher than atmospheric pressure until I unclogged the fitting. But that may have been remaining pressure trapped in the pipe.
Fraree
Australia Chapter
May 10, 2019 07:28 PM
greagin
Apr 21, 2007 08:41 PM
hansont
Dec 30, 2006 08:57 PM
SPODEBOY
Mar 30, 2006 06:54 PM
snowman63
1997 - 2003 F150
Apr 19, 2004 09:33 PM
