Fuel Line Tank-End Fitting
Old Jan 31, 2017 | 02:33 PM
paddler's Avatar
paddler
So I struck out with Ford and the board about the O-rings in the fuel line fittings that attach to the sender unit in the tank. Ford says no replaceable O-rings, and NAPA lists rings but can't get them.
Bronco Graveyard has replacement fittings, but 3 styles and 2 sizes. And I don't remember what the fittings were. We got both off with a spring garter tool, but I'm not so sure that's what the fitting is. And I didn't
check size. I'm pretty sure the leaking fitting is the return line.
I prefer to not have to partially drop the tank, cut off the offending fitting, figure out what it is and size, order, and put the truck together a week later.
Does anyone know what the size and style the tank-end fitting on the fuel line, that connects to the sender? Hair-pin, duckbill, or garter, and size? Likely 5/16 or 3/8.
Any help is greatly appreciated.
Old Jan 31, 2017 | 04:20 PM
madpogue's Avatar
madpogue
Supply is 3/8", return is 5/16". As for type, it's the type that uses this type of quick disconnect tool. Not sure what that corresponds to in the jargon on Jeff's site.
Old Feb 1, 2017 | 07:04 PM
pwjackson42's Avatar
pwjackson42
pick the old orings out, size them and replace with new viton orings. I pulled one for the short lines from up by the driver side front wheel and just replaced with fuel line and hose clamps. I may try to replace the orings and put the quick connect line back in some day. Probably switch to efuel before that anyways.
Old Feb 1, 2017 | 07:59 PM
paddler's Avatar
paddler
The problems is that there are 3 styles of connectors, and I forgot what the ones on the sender looked like and did not take pictures. One style, garter spring, has a "snout" with external O-rings that fit inside the , and the literature I've seen suggests these are on the engine. Both me and the buddy who helped me don't remember a "snout" or visible O-rings on the connector to the tank sender. The other two styles have internal O-rings deep inside the connector. Bronco Graveyard lists splice-in replacement connectors for about $20 shipped... and than looks better than going on a fishing expedition deep inside a tiny dark hole.
So I now know it's probably a 3/8 size... still uncclear what style. Looks like I wait until I lower the tank and get the fitting off. And maybe this time I won't be too confident (stupid?) to take pictures.
Dorsai
May 22, 2012 09:43 AM
johnarahill
Nov 21, 2011 01:38 PM
texasjack
Feb 12, 2009 01:51 PM
neevnav
16
Nov 17, 2007 09:15 AM
