TTB Swap
Old Jan 30, 2017 | 07:22 PM
chrisfp178's Avatar
chrisfp178
TTB Swap
I currently have a 1987 F-150 4x4 that has the ranger style locking hubs. I have an opportunity to get a Dana 44 TTB setup complete from an 1992 F-150.
Will the 92 setup bolt right up to my 87?
Thanks.
Old Jan 30, 2017 | 10:56 PM
Lead Head's Avatar
Lead Head
I'm confused as to what you're expecting to gain. Your truck already has a Dana 44 TTB.
Old Jan 31, 2017 | 04:50 AM
My4Fordtrucks's Avatar
My4Fordtrucks
He is looking to ditch the one piece manual locking hub like was used on the Ranger/Explorer.
Yes, it will bolt in There is no need to swap out the whole axle assembly unless you were planning on replacing the axle bushings and u-joints in your current axle. The parts that you need are from the knuckle out i.e. axle stub shafts, spindles and the brake rotor/hub assembly. Bronco graveyard has/had a conversion kit to do this swap. The picture will give you an idea of what needs to be changed.
I have an '87 Bronco and had fought the oddball system for years. The hi-shear nut failed several times. It would back off because the stress from the 35" tires.
Old Jan 31, 2017 | 06:27 AM
chrisfp178's Avatar
chrisfp178
Thank you for your reply. You are correct about my wanting to eliminate that hub. If I understand correctly I could retain use of everything up to and including the knuckles on my '87 correct? (Only hubs, spindles, outer axle shaft, etc. change?) However, I may just want to take the whole assembly from the '92 and re-do all the joints, bearings, seals, fluids, grease, paint, etc. and swap the whole assembly. Any feedback greatly appreciated.
Old Jan 31, 2017 | 07:39 AM
My4Fordtrucks
I believe that is correct.
I removed the assembly in my '94 to replace the axle pivot bushings and the 3rd member to replace the gasket and seals. It isn't really necessary to completely remove it to do that though.
ScreaminGertrude
Jul 27, 2019 07:51 PM
Y2K1TON
1978 - 1996 Big Bronco
Feb 10, 2015 08:00 PM
baverwolf
Dec 16, 2010 07:02 AM
Tennesseeduck
Oct 2, 2007 12:52 AM
gil791
Nov 30, 2004 09:17 PM
