53-55 Dash Extensions
Old Jan 30, 2017 | 09:50 AM
avf100's Avatar
avf100
I want to put a dash extension in my truck. Please post pics of yours and where you purchased it or did you custom make it.
Mid-Fifty sells several different ones and they bolt to the lower dash but they don't go straight down. They are angled forward. Not sure how it would look.
I also want the glove box door to open if possible.
Thanks in advance
Old Jan 30, 2017 | 10:53 AM
CharlieLed's Avatar
CharlieLed
I have mine made at Direct Sheetmetal to my specs. What I like to do is have the extension set back a few inches from the face of the dash, that makes the look better and it gets the panel out of the way of the steering column. I use 16 ga steel with no angle. Here is a pic of a friend's truck...the extension here is flush which brings it out into the leg area, that is why I prefer a recessed panel.
Old Jan 30, 2017 | 12:10 PM
DadOh1's Avatar
DadOh1
dash extension
mine, made it myself. Should have made more than 3 of the small A/C vents, kinda restricts the air in the Sacramento heat
Old Jan 30, 2017 | 12:14 PM
DadOh1's Avatar
DadOh1
oh yeah and since I used wood and inset it a little, it just took a little extra sanding (basically invisible) under the glovebox to let it open properly
Old Jan 30, 2017 | 01:32 PM
burnettd01's Avatar
burnettd01
Dash extension
Looks good - you did a good job.
How are things? Long time since we have heard from you.
Looking forward to another West Coast FTE Truckstock meet-up!!!
Take care
Dan
Old Jan 30, 2017 | 01:51 PM
Rusted56's Avatar
Rusted56
Love the wood, great idea.
Old Jan 30, 2017 | 08:10 PM
avf100's Avatar
avf100
Thank you for the lead Charlie. And I better check my leg clearance first. I am 6'4 and using the stock seat.
Old Jan 30, 2017 | 08:20 PM
56panelford's Avatar
56panelford
I made my own for both my trucks, this one is set back 1/2" under the dash
I used piano hinge and made new stays with a slightly different arc to them.
Old Jan 30, 2017 | 08:31 PM
avf100's Avatar
avf100
Those look good. That's what I'm looking for. Are they straight from the lh to the rh? Or do they follow the curvature of the dash on the ends?
Old Jan 30, 2017 | 08:43 PM
56panelford
I put a curve on the ends ,I'll have to check to see if I have a picture to post of take one tomorrow..
Old Jan 30, 2017 | 08:47 PM
56panelford
I think you can see where the curve starts on this picture and with a curved bend on the ends..
Old Jan 30, 2017 | 08:51 PM
avf100's Avatar
avf100
That's ok. I see the curve on the primer and green pic now that I looked closer.
Old Jan 30, 2017 | 10:12 PM
Rusted56's Avatar
Rusted56
Mine are like John's (but not as nice I think) and you can see the bend in the end. I made two because of the console, and moved it back on the dash, so the glovebox still opens.
Phy
Jul 7, 2011 01:31 PM
dadstan76
Nov 16, 2009 03:49 PM
scottjo
Sep 14, 2007 01:22 PM
gusso
21
Dec 24, 2006 05:57 PM
laptopgeek
Apr 10, 2003 10:03 AM
