Head/ Valve Problems?
Old Jan 30, 2017 | 09:47 AM
Cowboybrad351's Avatar
Cowboybrad351
I have a 1985 F-150 with the 5.8L Windsor HO, the truck runs spectacular when it is warmed up... But not quite what I would expect. When the truck is at a dead stop and you punch it, it stutters or backfires... Even after tuning the carburetor... The engine seemingly looses coolant every oil change but there is no evidence of where it could be leaking. My question, does it sound more like a cracked head, bad valves, or head gasket? Another question would be, doing a rebuild, minus crank and new heads, would that possibly fix my problem?
Old Jan 30, 2017 | 10:58 AM
1986F150six's Avatar
1986F150six
Welcome, Cowboybrad351!
Many questions. Is this truck new to you? Does the exhaust seem to emit steam even after warming up? Use the "search" feature and read about compression testing as well as leak-down testing. There are kits where a coolant sample can be tested for exhaust gasses. Do some diagnostic work before tearing into the engine for major repair.
You mentioned tuning the carburetor, but have you checked the sparkplugs, distributor cap and rotor or sparkplug wires? What about the ignition timing? That has a lot to do with how the engine performs.
Old Jan 30, 2017 | 04:46 PM
kr98664's Avatar
kr98664
I certainly wouldn't condemn an engine's internals without first replacing the spark plugs, plug wires, distributor cap, and rotor. A fault with any of those components could cause the problems you've described.
If no help, next is a compression test.
After that, you may want to consider a dynamic compression test. It's kind of odd and time-consuming, but will isolate problems (such as a broken valve spring) that won't show up in a regular compression test:
http://www.misterfixit.com/
As far as the coolant usage, you may find this recent thread of interest:
https://www.ford-trucks.com/forums/1...u-guys-do.html
FWIW, my 351W goes through a fair amount of coolant but I've never been able to track it down. I just keep the coolant topped off. $20 of coolant per year beats $2000 for a rebuild.
Old Jan 31, 2017 | 12:02 AM
kr98664's Avatar
kr98664
One more quick thing to check: The choke. After the engine warms up, make sure the choke is fully open. Remove the air cleaner cover and make sure the choke plate hasn't got stuck. I'd even suggest wiring the choke linkage fully open as a test. Make sure the normal throttle operation is not accidentally affected.
I was reminded of the choke after reading the resolution in this thread:
https://www.ford-trucks.com/forums/1...condition.html
One more thought on your concerns of the stumble being connected to a possible coolant loss. If you had an internal coolant leak, it would have to be really severe to cause poor performance. Any such problem that bad would be super obvious in a compression test or a pressure test of the cooling system. Definitely run some routine diagnostic tests before assuming the engine is toast.
Also, what about the accelerator pump operation? With the engine off and choke plate fully open, quickly cycle the throttle. You should see gas squirt down the carb throat.
Old Jan 31, 2017 | 06:54 AM
Franklin2's Avatar
Franklin2
I would check the accelerator pump operation in the carb like was mentioned.
GSlahor
Nov 28, 2017 02:27 PM
HowieE
Aug 5, 2016 08:28 AM
Tripp44
Jun 10, 2015 11:47 AM
strider3700
Feb 8, 2014 06:58 AM
1SG
Jan 26, 2004 10:13 AM
