93 lightning
Old Jan 29, 2017 | 07:27 PM
rigo sosa's Avatar
rigo sosa
93 lightning
Need to drop a new(used engine) in my 93 ford lightning. local junkyard has a a 5.8 but it is not out of a lightning . will this make a difference? will i have to replace computer? other parts? or will it be plug and play??
Old Jan 29, 2017 | 08:24 PM
Conanski's Avatar
Conanski
It is a bolt-in if you strip it to the bare shortblock and put the Lightning heads and intake on it but it'll be down on power a bit form the original motor, if you just put the Lightning intake on and don't change the heads it will still work but be even further down on power. If you wanted to get a slight upgrade in power with this swap then you also need to upgrade the cam as well, the stock L cam is a 5.0HO style grind but there are lots of aftermarket cams that are better. If you get a '94+ truck motor it will have a factory roller cam, anything older will be flat tappet and all these base motor cams are smaller than the L cam.
Old Jan 29, 2017 | 11:46 PM
ChRoNo16's Avatar
ChRoNo16
Owning a lightning and not keeping it a lightning is disrespectful.
Your lucky enough to own an awesome truck, rebuild yours or sell it.
Old Jan 30, 2017 | 12:28 AM
TexasGuy001's Avatar
TexasGuy001
I'd suggest either rebuilding what you have or getting a 94+ roller block and using a better cam and then keeping the L top end etc.
Osiyo59
Sep 16, 2012 03:56 PM
USMC0351fordtruckin
Jan 18, 2011 02:04 PM
broncobillybob
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Mar 23, 2005 11:40 PM
GypsyR
22
Feb 23, 2005 07:13 AM
LX96TBIRD
Jul 1, 2000 06:32 PM
