Oil Capacity/type?
Old Jan 29, 2017 | 04:28 PM
kcwolf200's Avatar
kcwolf200
Oil Capacity/type?
I am coming due for my first oil change and I'm confused. The manual states 15 qt capacity, but some on here are saying 13 qts. Those of you that have done oil changes, how much are you putting in?
Also, what are your thoughts on moving to 5W-40? I live in Indiana and temps can sometimes get below 0. Also, we tow a 10,000 lb travel trailer and make about 4-6 trips a year with about 1-2 of them about 1000 miles round trip. I just don't want to be changing oil weights back and forth, but not sure if I need to go to the 5W-40. My daily driving is about 25-35 miles with about 85% of that highway.
Lastly, should I use Motorcraft brand oil? I read that the oil manufacturers are moving to a new API certification that Ford does not support.
Old Jan 29, 2017 | 05:04 PM
cyncwby's Avatar
cyncwby
I just changed the oil in my '16 F350, you won't drain all the old oil but most of it. I put in 13 qrts of Rotella T6 5w40 and it showed full. I used 15w40 Rotella in my old '02 7.3 and the 5w40 is recommended by a bunch of guys on most diesel forums. You can use the Ford oil if you wish but I choose Rotella T6.
Old Jan 29, 2017 | 05:31 PM
mhoefer's Avatar
mhoefer
Any diesel motor oil rated API CJ-4 or better per your owners manual. This motor is different than the older types, so, synthetic and lower weights for starting not quite the same necessity, as a high pressure oil pump and HEUI injectors for the older types. Consult the chart for weights of Dino and synthetic for your operating needs and temperature ranges, i.e. Towing, cold starts.
Old Jan 29, 2017 | 05:49 PM
69cj's Avatar
69cj
13 quarts. Ford has stated the 2017 manual has a misprint.
Old Jan 29, 2017 | 05:53 PM
MagneticTiger's Avatar
MagneticTiger
Did they officially announce that? I must have missed it.
Old Jan 29, 2017 | 06:01 PM
mikehfrye's Avatar
mikehfrye
**** Warning ABOUT ROTELLA T6****
Rotella changed their formula for the T6 from CJ-4 to CK-4 in the last few weeks. At Walmart, I bought it and it was CJ-4 two weeks ago, today it is CK-4 on the shelves. Ford specifically does not support CK-4 at this time.
Please pay attention!!!
Here is the link
Old Jan 29, 2017 | 06:23 PM
TrikeDawg's Avatar
TrikeDawg
Here is a link that list the Ford approved oil for diesels.
Am I missing something by not seeing the Ford Motorcraft branded oil on this list?
https://www.fcsdchemicalsandlubrican...SSM2C171F1.pdf
Old Jan 29, 2017 | 07:35 PM
kcwolf200's Avatar
kcwolf200
So what weight oil are most people using?
That's also interesting that Motorcraft oil is not on that list....
Old Jan 29, 2017 | 08:55 PM
mhoefer's Avatar
mhoefer
Can't tell where you are or temps your experiencing. Are you towing? 15w40 Dino oil, or 10w30 if cold enough. Need 15w40 for towing. Or you can go a synthetic 0 or 5 w40 all year round.
Old Jan 29, 2017 | 10:37 PM
TrikeDawg's Avatar
TrikeDawg
I normally run the Rotella T6 5W-40W because that has been recommended for severe service or when using diesel with biodiesel in it. Just about all diesel now has biodiesel blended with it.
Old Jan 29, 2017 | 10:48 PM
DeputyDiesel's Avatar
DeputyDiesel
What about CJ-4/SM oil? Like Delo full synthetic
Old Jan 30, 2017 | 03:43 AM
spolk69's Avatar
spolk69
Man I been useing rotella 6 for years. What a good replacement for synthetic ?
Old Jan 30, 2017 | 05:01 AM
Bsherry's Avatar
Bsherry
Oil
I just changed the oil in my 2017 F350 6.7L for the first time. I used the Shell Rotella T6 5-40 CJ-4.
I called Ford customer service to confirm quantity of oil to put in? They said the manual is wrong-correct amount of oil for the 2017 6.7L is 13 quarts. Manual will be updated at next reprint.
Bruce
Old Jan 30, 2017 | 08:15 AM
Boilermaker374's Avatar
Boilermaker374
Shell ROTELLA® Responds to Ford?s Position Statement | Shell ROTELLA®
Old Jan 30, 2017 | 08:21 AM
Canwan's Avatar
Canwan
Your link doesn't work. This one should.
