Stupid question. What can cause my reverse lights not to work?
If the fuse is indeed good then check for power going in on pin 9 and out of pin 11 on the DTR sensor. See the PDFs for the diagram and connector pinout.
Test it as Alloro said first to ensure you are receiving 12v at the lights first. Once that is known, then check the ground. IIRC, they are grounded on the driver's side frame rail close to the rear tire.
STOP!
Original poster: Explicitly identify that you are working on a 99 F250 Super Duty. If you're working on one of those bazterdized [sic, swear filter ]F150s with F250 badges, it's a completely different critter. ALWAYS explicitly identify what you're working on. I, for one, don't bother wasting time poking around to try and find out stuff that you should have identified up front.
alloro: I get "drawing errors" in Adobe Reader when I try and open the two files you attached, it appears they may corrupted as seen on my end or my install of Reader is wacked. In any event, I suspect they're the drawings for the light duty F150/250 instead of the F250 Super Duty as F5 supplies that circuit on the light duty version. The Super Duty electrical layout is completely different and its schematic is attached.
pete/ny
16
04-24-2023 09:26 AM
Firelizard
05-27-2017 06:13 PM
bkks744
07-07-2008 06:10 PM
