Hey
Old Jan 24, 2017 | 10:33 PM
Bradmcfall123's Avatar
Bradmcfall123
Hey
This is my first time on here and my truck has 400,000 miles on it and I was wondering should I put a edge evolution tune on my truck
Old Jan 24, 2017 | 10:52 PM
erikkloss's Avatar
erikkloss
It might help if you tell us about your year , make, model, engine, trans.
Old Jan 24, 2017 | 10:54 PM
Bradmcfall123
It's a 2000 Ford F250 7.3 6 speed manual
Old Jan 24, 2017 | 11:44 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
How many miles have YOU put on the truck? Do you know its history?
Old Jan 25, 2017 | 05:25 AM
Bradmcfall123
I've put 380,000 miles on it and it had 20,000 miles on it when I bought at a dealer and it's vehicle history is good
Old Jan 25, 2017 | 06:34 AM
97-psd's Avatar
97-psd
No. An edge insight that monitors the truck is fine, but Edge tunes are problematic for the 7.3. There are several good tuners out there depending on yours needs.
What modifications does the truck currently have?
Old Jan 25, 2017 | 06:52 AM
Bradmcfall123
It's all stock everything is stock
Old Jan 25, 2017 | 11:42 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Tuning your truck for more horsepower can have consequences (especially with cheap tunes/generic tunes) if not prepared for and thought out. Some things to consider before tuning your high mile truck:
Age of all the o-rings and the two high pressure lines on top of the engine. These are now manufactured with better materials than were available when our trucks were made.
Health of the turbo center bearing cartridge. Check your compressor wheel for wear on the fins on the intake side.
Health of the transmission. It will be the first thing exposed if too weak/worn out to handle the extra power. If still stock, there are many upgrades to the internals available for the 4R100 that make it more reliable and sturdy.
Condition of the injector o-rings both internally and externally.
Condition of the up-pipes. Are they leaking and sapping your boost?
You should have gauges to monitor things (EGT/fuel pressure/boost/trans. temperature)if adding extra power to your veteran truck.
In short, make sure your truck is 100% before adding any kind of tuning for more HP and TQ, or you might be going down money-pit road like some of us have done.
Old Jan 25, 2017 | 01:54 PM
Stewart_H's Avatar
Stewart_H
I disagree based on the experience of a well respected tuner who used to work with Bill at PHP.
Bill at PHP, who at one time worked for Edge, wrote the calibrations for them, if I'm remembering the info correctly. Someone else can confirm that part.
Originally Posted by cleatus12r
Use it if it's there. There's nothing wrong with it. What model is it? Heck, your pickup may already be running one of the calibrations since it doesn't have to be "hooked-up" to do what it does (provided it is an Evolution and not a Juice).
EDIT:
The reason for the bad rap has little to do with how good or bad it is but instead with what people - who have no experience with one or the calibrations and how they're written have read about them on an internet forum just like this one - continue to regurgitate when threads like this come around.
If you have it, use it. If you don't like it you can take it off and resell it.
Stewart
Old Jan 25, 2017 | 03:07 PM
Bradmcfall123
Ok so I'm going to sell this truck in November and how much would I get for this truck
Old Jan 25, 2017 | 04:36 PM
Stewart_H's Avatar
Stewart_H
Not trying to be circular in logic here, or negative in any way, but how much you can get for the rig is based on how much someone is willing to pay.
As for pricing guide, you have to check the various online resources, as well as see how much similar rigs are selling for in your geographic area, when it comes time to sell.
Stewart
Old Jan 25, 2017 | 04:38 PM
Bradmcfall123
Thanks Stewart and I'm wondering what next ford truck should I get next
Old Jan 25, 2017 | 06:11 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
A lower mile 7.3L pickup!!!!
Old Jan 25, 2017 | 06:36 PM
Bradmcfall123
Well I want a ford f150 or f250 and I either want a newer f150 or a 7.3 6.0 or 6.4 and if the money is there a ford mustang gt
Old Jan 25, 2017 | 09:23 PM
Bradmcfall123
If I want a lower 7.3 what's the best trim out there to get. Basically what is the best 7.3 truck to buy
