Disc brake conversion
Old Jan 24, 2017 | 07:11 PM
kawasakiklx1's Avatar
kawasakiklx1
What's parts from a 76 2wd with disc will work in a 74 4x4 front disc conversion? Master cylinder, booster, proportioning valve, pedals? Obviously the spindles likely won't.
Old Jan 25, 2017 | 01:45 AM
HIO Silver's Avatar
HIO Silver
Booster, mc, pv, and pedal assy I figger.
Old Jan 25, 2017 | 01:02 PM
gittinwidit's Avatar
gittinwidit
Pressure valve is plumbed a tad different but same valve. 2wd has a plug and fronts are spliced where as 4wd fronts are ran separate from factory. I doubt it made any difference?
The calipers are the same but the actual hard lines into them are different for they go upward into a bracket on the frame on 2wd and downward to a bracket on the axle on 4wd
The pads are the same as well along with the caliper mounting pieces.
Rotors are way different.
Old Jan 25, 2017 | 01:07 PM
kawasakiklx1
Great, at least I have the cores for a lot of the parts. I'm guessing the pedal assembly goes with the booster? Will in be a direct bolt in exchange for booster?
Old Jan 25, 2017 | 02:23 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Upper pic: 1973/79 F100/250 2WD w/single piston calipers.
Lower pic: 1976/79 F100/150 4WD
2WD's don't have 2B292 caliper anchor plates (see lower pic), so the calipers do not mount the same way.
The 2K004/2K005 splash shields are specific to 2WD or 4WD
Old Jan 25, 2017 | 02:24 PM
gittinwidit
Lower pic: 1976/79 F100/150 4WD.
Oops. wrong post. LOL
Old Jan 25, 2017 | 02:26 PM
gittinwidit
Sorry for quoting ya there number!
hfd315
Sep 25, 2017 01:30 AM
66low
Feb 20, 2015 11:28 AM
Ddg0919
16
Sep 29, 2014 07:33 PM
deyomatic
Sep 2, 2013 05:17 PM
SeaBeeCm1
Jun 11, 2011 08:23 PM
