Engine stutters
Old Aug 27, 2003 | 11:06 PM
Vgengooms's Avatar
Vgengooms
Engine stutters
Well here is my problem. I let my brother borrow my Bronco for a weeK. I get it back and it runs like crap and the brakes were shot. I have fixed the brakes and now need to move on to the engine. It is a stock 400 with the stock 2150 carb. I jetted up a while back (8 months or so), and killed the EGR. Also I added a MSD Coil and that is it.
Now on to the problem. Jr. seems to stutter really bad now. It does not matter if it is under load or not, I pulled the plugs thinking that they were fouled but that did not help. Could it be time to rebuild the carb? Is my Dist shot? Is my new coil gone? Any help would be great. Thank You.
Old Aug 27, 2003 | 11:11 PM
Torque1st's Avatar
Torque1st
Posting Legend
Engine stutters
Have the ignition module tested. Hot weather is a killer...
Old Aug 27, 2003 | 11:16 PM
Vgengooms's Avatar
Vgengooms
Engine stutters
I didn't even think of that Can I have that done at any carquest or autozone, I have had alot of things tested over the years just not that.
Old Aug 27, 2003 | 11:59 PM
Torque1st's Avatar
Torque1st
Posting Legend
Engine stutters
Most good parts stores have a tester and will do it for free. Test the distributor pickup module also if the spark module checks out good.
Old Aug 28, 2003 | 01:13 PM
Vgengooms's Avatar
Vgengooms
Engine stutters
I had the modual checked it was fine. Forgot about the dis. pickup mod. I think it is a bad needle and seat. or bad float?
Old Aug 28, 2003 | 02:25 PM
Torque1st's Avatar
Torque1st
Posting Legend
Engine stutters
How many miles are on the engine? The stock timing chain gives out at about 100K.
Old Aug 28, 2003 | 10:14 PM
Vgengooms's Avatar
Vgengooms
Engine stutters
I'm pretty sure it is past 100K. It was a junkyard motor. Could it have jumped a tooth?
Old Aug 29, 2003 | 04:25 AM
tall1's Avatar
tall1
Engine stutters
If your chain jumped a tooth then the timing will be off. Check that unless you moved the dist. already. I have had the small pick up tubes in the carb get junk in them causing a miss, pull the center venturi with the accelerator pump nozzles and check for a clogged tube. And dont forget to look for a vacuum leak..
Old Aug 29, 2003 | 08:27 AM
Vgengooms's Avatar
Vgengooms
Engine stutters
Thanks, I'm going to pull the carb this weekend and take a look. I'll check the timming this weekend. I really like this board, thanks for all the help.
Old Sep 1, 2003 | 10:01 PM
Vgengooms's Avatar
Vgengooms
Engine stutters
Well I rebuilt the carb this weekend, I found the accelerator pump check valve was torn. I rebuilt the carb after a good cleaning. Now I have noticed That it is not as bad of a stutter, but, it is still there. I checked the timing it is fine (10° BTDC), But I noticed that there is a slight "tap" coming from the #1 cy. I'm stumped. Please help. I will find a place to test the distributor pickup module tomarrow.
toddev
Nov 13, 2013 10:59 AM
fordcrzymike
1997 - 2003 F150
Feb 4, 2013 06:17 AM
DJones71
Dec 20, 2004 03:46 PM
