recognising a 351w
Old Aug 27, 2003 | 10:00 PM
g-a-w-d's Avatar
g-a-w-d
recognising a 351w
Hey, How can I tell if my motor is a 351 or 302? Its suppose to be a 351, but I just saw something and now its got me thinking it might be a 302.
Thanks
Old Aug 27, 2003 | 10:02 PM
fordzman's Avatar
fordzman
recognising a 351w
a 302 has a 9 inch wide intake and a windsor has an 11 inch intake....
Old Aug 27, 2003 | 10:39 PM
circledirt's Avatar
circledirt
recognising a 351w
lower bolt of thermostat housing on 351 is easy to remove, on 302 its behind timing cover
Old Aug 28, 2003 | 10:54 PM
MatthewP's Avatar
MatthewP
recognising a 351w
One of the easiest ways to tell the difference is to look at the distance from where the distributor seats on the block to where the lower intake mates with the block. On a 351W this is about 1 inch. On a 302 these parts are nearly flush. This is because the 351W has a 1 inch higher deck height.
-Matthew
Old Aug 29, 2003 | 07:09 PM
fordtrks4fr's Avatar
fordtrks4fr
recognising a 351w
also the firing order in most cases will be 13726548 on a windsor
Old Aug 29, 2003 | 07:12 PM
fordtrks4fr
recognising a 351w
inless it a 302h.o. or someone put a 302 cam in a windsor.
