Sponsored by: Real Truck
Quick question about OEM wheels
Old Jan 23, 2017 | 11:49 AM
AAubinoe's Avatar
AAubinoe
Hi,
Have a 2016 F250 with steel wheels and want to put a factory alloy on it. My favorite alloy is the 05-07? 17" with round holes. (I've always preferred running the smallest wheel possible with the biggest tire possible) I found a set in great shape.
This is the wheel: http://www.wheelsandcaps.com/Ford-F250SuperDuty-2005_p-21296-aluminum-alloy-wheel-rim-17x75-3599.aspx?variantid=21329&ref=g-pla&gclid=CKbEw4Pp2NECFU1LDQodEKcFAg
I found a ton of threads about putting wheels on a coil sprung truck onto a 99-04 leaf sprung truck. Can I assume that all 05-16 wheels are essentially interchangeable and will sit in the same position as my 17" steel wheels?
Secondly, are these wheels forged? (Are all OEM super duty aluminum wheels forged?)
Seems like simple questions, but could not find any clear answers! Thanks very much.
Old Jan 23, 2017 | 12:23 PM
Kdr358's Avatar
Kdr358
All 05 + wheels will interchange, however you might run into a TPMS light issue which may require swapping the sensors over.
Old Jan 23, 2017 | 03:59 PM
AAubinoe's Avatar
AAubinoe
Cool thanks! Going to keep the stock steel wheels and tires for winter use, and get new sensors for the aluminum wheels.
Old Jan 23, 2017 | 06:49 PM
RainDesert's Avatar
RainDesert
I put 17's on my 2016. There was a hair of room between caliper and wheel. I'd always wished I had waited for 18's due to that clearance. So I recommend 18's. Here is a pic of 17's on my my 2016 and 18's on my 2017. The 17's were aftermarket 8 hole, the 18's were factory 8 hole from a 2007.:
Old Jan 23, 2017 | 08:12 PM
AAubinoe's Avatar
AAubinoe
Wow nice trucks! Do you still own both? Both 6.2l? Really excited about the new boss engines!
If the 17s will fit that's good enough for me. Wish I could run 16s like on my 2004 (especially the 99-04 16" round hole Alcoa's)! Although the 18s are nearly an identical style. They look friggen great on that 17, don't really understand the appeal of the crazy style wheels.
Going to run 285/70 R17 Cooper ST Pro tires on them!
Put Nitto tires of the same size on my dad's 2010 work truck and they fit perfect and look great.
Old Jan 23, 2017 | 09:32 PM
RainDesert's Avatar
RainDesert
Both are 6.2's. I just have the '17 now. My 2016 had 285/70/17's on it in that pic, the wheels were "0" offset so they stuck out quite a bit, that's one thing I didn't like. But you can't find much for simple 8 hole wheels with a +18mm offset. The 285's looked good, I also think the 295/70/17 would have looked just as good, if not better.
Old Jan 24, 2017 | 08:04 AM
Toolman76's Avatar
Toolman76
'05 wheels with 285/70r17s on my 2016.
RenoHuskerDu
15
May 27, 2025 09:18 AM
BigBlueOx
6.7L Power Stroke Diesel
Feb 3, 2015 10:06 PM
LARIAT 85
22
Jan 2, 2011 05:59 PM
fairlaniac
1983 - 2012 Ranger & B-Series
Dec 19, 2008 06:00 PM
