00 Explorer lock-up falls out
Runs and shifts fine other than this. Only thing I have noticed is that the temp gauge reads pretty low but I think this started earlier and I understand that the temp gauge has its own sensor.
Any ideas where to start looking?
Also, throttle position affects lockup. If your TPS has a bad spot right around where you cruise (which is where they tend to wear out), then it could be causing the torque converter to unlock. Can you get it to lock back up by pressing gently on the throttle to get the TPS off of its normal spot at cruise?
Don't run out and replace the TPS and temperature sensor (not to be confused with the sender). The above are just guesses on my part and further troubleshooting is required. You could have a wiring problem, too, in either of the sensor circuits or torque converter clutch circuit.
Temp gauge reads just a tad over "cold", like 1/3 of its way to "normal".
When lock-up disengages it lights the "contact tech" (or simular) light in the dash and no throttle action will make it go back to normal. Ignition switch has to be turned to "off" position to clear it. A split second in off-mode is enough and it always cures the problem for a while. Sometimes for a couple of miles - other times for the rest of the day. More ideas?
Can you explain the difference between sender and sensor?
That could mean lots of things, but remember all it takes to turn off the light and get the converter to lock up again is a quick turn of the key to "off" position. Even done so fast that the engine doesn't stop is enough to get it back to normal.
Any ideas? Lockup solenoid?
The computer will monitor the converter slip and if it slips enough to fall out of a acceptable range enough times the computer will set a code turn on the CEL or OD light and disable lockup, cycling the key resets the computer to watch the converter and it repeats the failure all over again.
Most likely the converter is slipping due to a internal leak in the lockup hydraulic circuit, it can be with the valve body or solenoid or the converter itself.
I rarely have to replace the solenoids on these but I do see a lot of converter and valve body issues.
I understand what you are saying. Makes sense. Trying to narrow down the problem a bit:
-Code 741 is often caused by low apply pressure. Could be worn TCC valve bore?
-Leaking valve body? Doing a wet air test with proper adapter?
-Converter itself?
-TC solenoid (not likely as stated)
-Worn CCS valve (not likely as it shoud take away several gears)
Everything other than the lockup works great in this trans. Other than disabling the lock up I notice that it is somewhat slow/late to engage the lockup - like it needs some time with steady light pedal at normal speed to engage lockup.
I need help to decide where to start eliminating causes.
