Australia Chapter Join Chapter , Leader: OPEN
towing legally
Old Jan 21, 2017 | 01:14 AM
kingswood202's Avatar
kingswood202
towing legally
hey i'm new to the forum joined as i've been looking to buy a old school f truck to tow my old school cars mainly to the drag strip
now i've been looking at 100 up to 350 but most of these old rigs have no tow rating and its near on impossible to find anything online as'well
i'm looking to be able to tow 2.5T will i be able to do this legally
thanks for your help guys
Old Jan 21, 2017 | 11:34 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Before formal tow ratings, the registration body set the limit at 1.5x the tare weight for "goods carrying vehicles" (i.e. utes), or 1x the tare weight for cars.
This would put most of them in the 2.5-3T range for towing a trailer with brakes. I believe Hayman Reese make a tow hitch for the older trucks that is rated a 2.8T, so that is probably your answer!
Old Dec 21, 2018 | 12:43 AM
ozbmx's Avatar
ozbmx
I know what you mean I've also 4.5t rated hayman reese bars with f100 on the plate.
but it's still in the grey area but i think we get away with more than legal being an older bigger ute.(not say more legally just less likely to be looked as closely as it's in the 2 hard basket.)
it may be as low as 2.5 t on an f1 of this era but you'll be pretty safe with an f350 to be good for atleast 3.5 ton.
​​​​remember rails etc. Are actually thicker
but i was amazed how difficult it is to find this info e.g. ford can produce a rgvm which is your combined weight generally the limiting factor.
but they don't have it at hand easy.
Old Dec 21, 2018 | 07:45 AM
Blackduck59's Avatar
Blackduck59
Ford varied a lot, what year are you looking at?
My 86 F350 is rated to 4.5T but it also requires a light rigid license. it changes with the engine fitted, transmission fitted and final axle ratio as fitted..
Next thing I will be looking at is to get it rated below 4535 KG, there is an administrative change in VS6B for import vehicles to reduce the mass below 4500.
Cheers Steve
seventyseven250
All Things Towing
21
Feb 14, 2018 06:37 AM
airbats801
Nov 3, 2012 04:14 PM
smokersteve
Sep 2, 2012 10:44 AM
Jarniscipus
Feb 20, 2011 01:01 AM
aquaholic
All Things Towing
22
Mar 21, 2007 05:29 PM
