Vacuum lines 460 engines
Old Jan 20, 2017 | 06:11 PM
Nzell3's Avatar
Nzell3
Can anybody tell me the proper connections for the vacuum lines off of the 460 manifold.
Old Jan 20, 2017 | 06:22 PM
HIO Silver's Avatar
HIO Silver
NOT ENOUGH INFORMATION PROVIDED...
What year?
In which state are you located?
Are you subject to emission controls testing or visual inspection?
Transmission?
Help us to help you....
Old Jan 20, 2017 | 10:09 PM
PapaBearYuma's Avatar
PapaBearYuma
For starters, there's a big one to the power brake booster. If you have automatic transmission, that'll get a small one. There'll be another small one that goes inside the cab for the heater/AC controls. If you have cruise control, one may go there.
Looks like you don't have an EGR plate, so we won't mention that one
You'll have a ported vacuum from high on the carb to the distributor.
Depending on what's left, you may have lines to the door on the air cleaner, to a vacuum can or two, likely two off the thermostat housing and maybe some others.
Old Jan 23, 2017 | 09:08 AM
Nzell3's Avatar
Nzell3
1978 Ford f100
I installed a 460 engine along with a c6 transmission. Emission inspection is not required.
Old Jan 23, 2017 | 11:19 AM
PapaBearYuma
I put mine back together yesterday. 460 C6.
All it needs is:
the big line to the power brake booster
a smaller line to the transmission shift modulator
a ported vacuum to the distributor (from the carb)
RBraverman
Feb 10, 2015 08:12 PM
solo pilot
39
Jan 16, 2014 11:16 PM
littleme13
Apr 13, 2006 09:17 PM
quentinorciuch
Jul 23, 2004 06:37 PM
mdan575
Nov 25, 2003 03:18 PM
