2006 Mountaineer blower issue
Old Jan 19, 2017 | 06:57 PM
Michael Yescavage's Avatar
Michael Yescavage
Hello everyone,
I'm looking to get some help on an issue I've tried to look for on here and on google. My 2006 AWD v6 Mountaineer blower motor had issues starting up and the only way for it to start is if I tapped the wires under the glovebox and then it would kick on but very little air would be coming out.I replaced the blower motor resistor thinking it would be the issue but it only fixed the speed issue and now blows strong but I still have to tap the wires for it to kick on. Could it be the actual motor itself or could it be just a loose wire? It only gives me problems right now cause the temps have been dropping into the negatives.
Old Jan 20, 2017 | 06:43 AM
projectSHO89's Avatar
projectSHO89
If you have to fiddle with the wires to get it to start, then there's probably an intermittent or loose connection in there. If you had to tap the motor itself, that would indicate a motor with worn out brushes.
Old Jan 20, 2017 | 11:08 AM
Michael Yescavage
Thanks for responding back projectSHO89. I will run through the wires and make sure the connnections are tight and aren't loose and hopefully that will solve this issue.
Brad ORourke
Mar 4, 2019 10:43 AM
annaleigh
Jul 24, 2016 09:11 PM
F-150Freak
2004 - 2008 F150
Jul 28, 2011 06:50 AM
irydhd
2004 - 2008 F150
Apr 5, 2010 01:56 PM
boggerted
Jul 18, 2007 02:15 PM
