Replacing Wheel Studs
Old Jan 17, 2017 | 10:09 PM
dwstenersen's Avatar
dwstenersen
Hello Everyone, 1992 F150 XLT Lariat (Front disc, rear drum)
Today while getting a balance and rotate at Costco, the worker told me he could only get 3 of 5 lugnuts on my Driver Rear wheel. Having experience as a tire technician I went in and tried myself. I knew 1 was completely stripped when I bought the truck but the 2nd one took me by surprise. If i'm honest, the last time i put on the 4th one it went on pretty hard and I probably stripped it.
Costco paid for my tow home and gave me a ride home free of charge.
I have no experience replacing wheel studs, but i bought this truck to learn on. Can anyone give me a difficulty level for this type of job? would the rear have enough clearance to press the studs out and fit new ones on without removing more than the drum rotor?
Old Jan 18, 2017 | 07:11 AM
DrZoom's Avatar
DrZoom
I'm getting ready to do all of mine. Previous owner probably used an impact gun to crank them tight, so the threads are all galled.
They just hammer out - get a BFH or (ideally) an impact hammer. Not sure if there is enough clearance to cleanly knock them out (should be) but if not, you could always knock it loose, then cut the stud off and push the back piece out.
Get the new studs seated before you put your wheel back on by putting on a few washers and torqueing down a lug nut. Don't use the wheel installation to seat the stud.
These trucks are great for learning. I had never pulled a transmission, rebuilt an engine, or done anything much more than suspension work before I got my truck. Have fun!
Old Jan 18, 2017 | 08:17 AM
dwstenersen
Thanks buddy! I've watched a couple of youtube tutorials but I was skeptical about how simple it looked. Should be an interesting weekend project!'
Any recommendation on a spacer to use? I see they sell ones for the job, but they seem a bit pricey for something so simple
https://www.amazon.com/Lisle-22800-W...ct_top?ie=UTF8
Old Jan 18, 2017 | 08:58 AM
Mudsport96's Avatar
Mudsport96
You can probably use a 3/8 pipe coupling from your local hardware store. Under 2 bucks I'll bet.
Old Jan 18, 2017 | 11:25 AM
DrZoom's Avatar
DrZoom
Any heavy piece of pipe that slips over the stud will do. I've even seen people just stack a bunch of washers. Obviously you don't want the spacer to thread onto the stud.
Old Jan 18, 2017 | 11:38 AM
dwstenersen
That makes sense. I'll just take the new stud to a local hardware store and find something that will work. Really appreciate all of the help!
Old Jan 18, 2017 | 06:38 PM
valkyrie9901's Avatar
valkyrie9901
Turn the lug nut over when seating the wheel stud as not to mess up the tapered side.
Old Jan 19, 2017 | 08:32 AM
dwstenersen
Is the process going to be the same for the front after removing the rotors/calipers?
Old Jan 19, 2017 | 08:39 AM
DrZoom's Avatar
DrZoom
You bet. Same deal.
Old Jan 19, 2017 | 08:58 AM
dwstenersen
Might as well do them all! Thanks!
Old Jan 20, 2017 | 09:38 PM
kellen302's Avatar
kellen302
Rent a C clamp style ball joint press from autozone/oreillys and press them out with the drum and hardware off. There is a cutout that allows enough space to fit the back end of the press behind the stud. This is the factory procedure from my Factory Service Manual. Don't hammer them out as that puts shock thrust loading into your wheel bearings and differential gear sets which is bad.
The spacer when installing should be greased washers to provide a rudimentary thrust bearing while you torque the stud through to prevent turning the stud and stripping the splines, retorque every 50mi for the first 1-200mi.
dark_flame221
May 4, 2010 09:23 AM
I6power
Aug 2, 2006 12:07 PM
couleeman
Apr 26, 2005 09:18 PM
I6power
Feb 24, 2005 05:35 AM
ferguson777
Dec 5, 2002 11:18 AM
