Sponsored by: Real Truck
6.2L towing
Old Jan 17, 2017 | 09:53 PM
Swamplife's Avatar
Swamplife
6.2L towing
Hopefully this isnt to mich of a dumb question.
2011 F250
4x2
6.2 L
3.73 gears
My question is I have read the towing guide and states 12,400 for gooseneck. I will be moving from CO to Fl and the weight of the gooseneck will be extremly close to max. Has anyone towed in the 12,000 range with this setup. I know the engines built today are allot better I just dont want to overload my truck. Any advice or recommendations welcomed thanks.
Old Jan 17, 2017 | 09:58 PM
JoeyCap's Avatar
JoeyCap
I've pulled more than that with a bumper pull. You will be fine but air bags would be a good choice.
Old Jan 17, 2017 | 10:04 PM
Swamplife's Avatar
Swamplife
Are airbags a difficult task to install or is everything pretty much bolt on? Any recomendation for brand I have seen allot about Firestone
Old Jan 17, 2017 | 11:31 PM
salomon's Avatar
salomon
Air bags are a bolt on install. If you aren't adding on board air compressor, 1.5hr install.
Firestone is a quality kit.
Old Jan 17, 2017 | 11:59 PM
DavidT.'s Avatar
DavidT.
Yes I have, 2014 model similar to your setup. A few things:
1. Be patient.
2. Motor will rev a lot on hills.
3. Very bad MPG.
4. Pulls just fine on flat ground.
5. Tow/Haul mode works good w/engine brake coming down hills.
The truck I used had an aftermarket exhaust on it and pulling that much weight I wish I had ear plugs on during the longer hills. That's about it. The 6.2 is a pretty stout gas motor and should do the job just fine
Old Jan 18, 2017 | 01:46 AM
farwhitenorth's Avatar
farwhitenorth
I drug a 24' enclosed trailer loaded to the gills from Missouri back to Alaska. Based on the fact I was blowing tires on trailer, I was over 12k. 6.2 with 4.10 gears. I was very impressed. Having owned diesels, 6.8, 6.2, I was very pleased. Yes, it likes gas and rpm's!!
Old Jan 18, 2017 | 05:16 AM
Ron94150's Avatar
Ron94150
4.10's were never an option with the 6.2, only 3.73 and 4.30.
I wouldn't hesitate to pull that weight. With the 3.73's, you might as well lock out 6th gear and save your transmission a bunch of shifting. Just do some routine maintenance before you head out and max out your tire psi. expect 6-9 mpg depending on the terrain your in. You will find it tows much better at 65mph than it does at 70 and 75mph.
Timbrens are another great option that a lot of people on here like. Super easy install.
Old Jan 18, 2017 | 06:21 AM
Swamplife's Avatar
Swamplife
Thanks for all the replies I feel allot better about this now.
I do regular maintenance oil change every 5,000 miles all Ford parts. I was thinking of getting the transmission flushed about a month before trip. Shouldnt be to bad on hills and terrain as I am going east coast and will probabbly head down to texas and hit I10. Im not a mechanic but I do use my manuals anytime doing work ie haynes. I was quoted about 1,100 for having a B&W 30,000 gooseneck installed but not sure how on point that is. That also looked like a novice job except making sure the hole is cut perfect. Is there anything besides transmission flush oil and breaks that would benefit before heading out. Thanks again for all the help.
Old Jan 18, 2017 | 06:26 AM
Ron94150's Avatar
Ron94150
I've never installed a gooseneck, but as far as cutting out the hole goes, there is a spot in the bed stamped in. It even has a center mark for you. Just buy a hole saw.
Old Jan 18, 2017 | 06:38 AM
Swamplife's Avatar
Swamplife
I will have to double check i didnt see any thing stamped I thought that was done in 2014 and newer mine is 2011.
Old Jan 18, 2017 | 06:50 AM
Slowpoke Slim's Avatar
Slowpoke Slim
I have a '12, and I pull 11,800 lbs with mine, it's the one in my sig. No problems what so ever, even with the 3.73 gears that it's popular to hate on these forums. You will be fine. I have the B & W turnover ball hitch (plus companion 5th wheel hitch) in mine, but had it (and the air bags) installed. Great hitch, very happy with it. Same with the Firestone bags. I didn't put a compressor on mine, and use a single air fill. It's fine. I do carry a small 12v compressor in my truck tool box, just in case I need to add air while on the road (I haven't needed to).
Manual mode on the transmission is your new best friend. Seriously, you must try this. It has made all the difference for me and towing my 5er. It's like driving a different truck.
Make sure your trailer brakes work, and are properly adjusted, and this trip will be a non-event. This is what these trucks were designed and built to do.
Safe travels.
Old Jan 18, 2017 | 07:04 AM
Swamplife's Avatar
Swamplife
Thanks for the info only reason i doubted some of doing the trip is
1. Max tow on a 1,700 mile trip 3 days driving
2. Allot of people have always told me to stay 1,000 lbs under max at least
( I know this was probably right with older trucks but I do think the 6.2 is a well built for this)
Glad i joined this group good info thanks
( Having the option with companion hitch is what made me want the B&W I do plan on getting a 5ver later down the road)
Old Jan 18, 2017 | 07:30 AM
Ron94150's Avatar
Ron94150
You may be right. Could not imagine them stamping the inside of the bed different in the middle of a generation that the entire body was unchanged.
Old Jan 18, 2017 | 07:32 AM
Swamplife's Avatar
Swamplife
I hope they did I have never taken the bedliner out I deff will today though. Thanks
Old Jan 18, 2017 | 03:08 PM
Swamplife's Avatar
Swamplife
I stand corrected i lifted my bedliner and there u go already tamped. Thanks again for all the help. Lokngbforward to the upgrqdes and towing this rig.
