Cargo light
Old Aug 27, 2003 | 05:36 PM
renglehardt's Avatar
renglehardt
Unhappy Cargo light
I am at wits end. I've tried everything I know to get my cargo light working and don't know what else to do. I have known good bulbs, all fuses are good (although they do not show a fuse for the high mount stop and cargo light) but I am not getting any voltage to the sockets for the cargo lights, the high mount stop light works. Please tell me what else I should check because I need help. Is there anything in the power distribution box under the hood that I need to check?
Old Sep 2, 2003 | 09:55 AM
garymake's Avatar
garymake
Cargo light
I know I'm stating the obvious here, but it sounds like you have a broken wire.
I would remove the light from the cab (the whole light assembly - not just the cover/bulb), check the color of the wire running to the cargo light and then start looking under the dash for a wire matching that color.
I would then verify that the matching wire under the dash has power when the conditions are such that the cargo light should be on (door open, dimmer turned up all the way, etc.) to verify that it does indeed go to the cargo light.
If it is the right wire, I would then check the continuity of the wire from where it has power to the light itself. If it doesn't have continuity, then you probably have a broken wire....
To further verify this, I would tap into the wire under the dash and run a temporary patch wire out the door and up to the cargo light to make sure that the problem isn't the light socket itself.
Hope this helps....
ccmoto286
Mar 8, 2012 05:47 PM
air1jpg
2004 - 2008 F150
Nov 1, 2009 08:36 PM
BIG-COUNTRY
Electrical Systems/Wiring
Mar 23, 2007 06:17 PM
Firefreak30
1983 - 2012 Ranger & B-Series
Oct 5, 2003 05:47 PM
renglehardt
Aug 28, 2003 12:19 PM
