F150 morning start problem
Old Jan 15, 2017 | 06:46 AM
Jst123's Avatar
Jst123
I bought 2010 f 150 platinum ..it has some after market performance parts K@n filter .flowmaster exhaust ,plugs .morning start first start of the day truck will try to turn over but nothing will start if apply gas ..once started no problems starting after that no Engine light any ideas ..
Old Jan 15, 2017 | 07:50 AM
ubereal2's Avatar
ubereal2
Sounds to me like it's time to get that battery checked, as well as the charging system of the truck. Good time to inspect the battery cable, and ends. Nice, clean, no corrosion, and tight.
Old Jan 15, 2017 | 08:31 AM
Jst123's Avatar
Jst123
Thank you will try that .. seems like it's not getting enough fuel someone told me mass air sensor? After it's started .. starts no problem every time
Old Jan 15, 2017 | 10:01 AM
brokenleg's Avatar
brokenleg
Is it cranking slow? or it doesnt start well first thing? if your truck has the original battery, its going to be pretty old.
Old Jan 15, 2017 | 01:21 PM
Jst123's Avatar
Jst123
Not cranking slow sounds like wants to turn over .. battery replaced last year .. cleaned and tightened battery back but same result just had it towed disappointing...always drove a Gmc thought I f150 platinum.
Old Jan 15, 2017 | 03:08 PM
ubereal2's Avatar
ubereal2
THAT, sucks. Did they at least hook up cables and try to jump start it? I've had newer batteries, develop a short and peter out.
I hope it's nothing major.
Old Jan 15, 2017 | 03:56 PM
Jst123's Avatar
Jst123
Yes thanks me to I will post what problem was .. thanks for the help ...I want to be a happy ford driver lol maybe an excuse to get a new 1 .. I did buy used
Old Jan 15, 2017 | 04:13 PM
brokenleg's Avatar
brokenleg
hope they find the problem
Old Jan 16, 2017 | 02:52 PM
Jst123's Avatar
Jst123
It's fuel pump module.... day and half to get part .. not 1 in area:/ .. don't even know how much part is or labour also said could be fuel pump .. sucks when u need ur truck for work .. gets expensive ...says common problem so why would even dealerships not have parts .. maybe should have stuck with gm
mark227
Dec 16, 2016 12:17 PM
sammatt1
Mar 24, 2014 01:00 AM
DyceDesign
Dec 2, 2009 12:10 PM
caseyb1tx
2004 - 2008 F150
Jan 4, 2009 09:31 PM
ford5.8
Aug 28, 2004 11:43 AM
