'53 cab alignment
Old Jan 15, 2017 | 06:27 AM
Marten's Avatar
Marten
'53 cab alignment
When measuring from the centerline on the back of my cab to each frame rail I have 14 1/2" one way and 15 1/4" the other way. Is this normal? How do you align the box to the cab then, follow the frame or the cab?
Thanks
Marten
Old Jan 15, 2017 | 08:53 AM
FortyNiner's Avatar
FortyNiner
The alignment issue is really only noticeable from the bottom up, right? If this were mine, I would align the box to the cab and move along.
I trust that the cab mounts are sound and properly installed.
Old Jan 15, 2017 | 12:57 PM
Marten's Avatar
Marten
No it is a left to right alignment that is off. Up and down I can deal with. I notice it when you look at how the box relates to the vertical lines in the back of the cab.
I believe the cab mounts are correct, did them twice, lol. Is there a difference between the left and right rear cab mounts?
Marten
Old Jan 16, 2017 | 09:37 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
No difference in right and left mounts. MidFifty has an adjustable rear "dogbone"
Old Jan 17, 2017 | 12:03 PM
petemcl's Avatar
petemcl
I would check your cab mount bushings particularly in the rear. Then check your 4 front frame mounting holes for wallow (see pix).
These mounts will impact a lot of things including hood closing efforts and alignment.
BJ is right about the availability of the adjustable rear mounts but you should not need them unless your frame is warped. I would check everything else on the cab mountings first.
FordHammer
Aug 5, 2014 04:53 PM
Outlaw56
Jan 10, 2013 06:44 PM
leonharu
Feb 24, 2008 07:34 PM
tip49
Oct 22, 2007 08:34 PM
fordxxx
Dec 22, 2004 08:48 AM
