Sponsored by: Real Truck
Need help wiring back up camera
Old Jan 14, 2017 | 08:58 PM
scumbum's Avatar
scumbum
Just joined this forum and am looking for help to wire the factory back up camera to an after market HU. I just need to know where to tap into the video + and - wires on a 2008 F-250 Super Duty. I'm sure this has been covered in previous threads but I haven't come across it yet. Thanks.
Old Jan 14, 2017 | 09:08 PM
agpopp's Avatar
agpopp
Do you mean use some type of factory provided wire for the camera? If so, if you have a job 1 truck, I don't think the harness was there. Otherwise, you could pick up the 12v at the trailer plug fir steady on with key, the reverse light for on on when in r and just add or tap a ground.
Old Jan 15, 2017 | 01:07 AM
scumbum's Avatar
scumbum
Need help wiring camera
I have already connected the reverse wire behind passenger kick panel. I just need to know which two wires are video+ and Video-. I also need to know where the VSS is located.
Old Jan 25, 2017 | 02:23 PM
acecase's Avatar
acecase
Mirror, see pic.
Old Jan 25, 2017 | 02:28 PM
acecase's Avatar
acecase
It's also in the passengers side pillar behind the grab handle. See my post at https://www.ford-trucks.com/forums/1...l#post16893424
It will be the only wires with a shield.
Hope this helps.
GMoney1121
Nov 23, 2024 07:20 PM
ngng
6.7L Power Stroke Diesel
32
Feb 24, 2022 09:56 PM
TIKT B8
Jun 17, 2010 12:37 PM
akcajunz
Feb 11, 2007 09:26 PM
trojanman1
Jun 21, 2005 12:37 PM
