E-fuel: Beans, irate, bar none, someone else?
So after deciding not to get the beater F250 I was looking at (because honestly, I can'y afford to spend 2500 now and have potential more issues when my poor bronco needs some love), I made up my mind that I am going to order E-fuel as soon as possible.
Before I make the jump on the purchase, I'd like to know what brand you guys think would be a good one to go with? Right now, I'm considering beans or bar-none. I read Bar-none doesn't need the turbo removed while other setups do, but then read things about some people not liking their fittings.
Basically any experience with these kits would be nice! I'm trying to stay at or under 1k for these kits, I know some go for about 1500 and I don't think I can spend that amount of coin now.
I know they can be built for less, but I don't think I want to go through the hassle of trying to piece together my own setup now when I don't know how the whole setup is supposed to go together. I'd rather have the kit ready to install instead of trying and piece things around for several weeks or more! I know that if I tried building my own, several things would come up and my Bronco would be down for probably a month or more. I'm sure once I see an electric fuel kit, I'll feel more comfortable in making my own for my next powerstroke!
After building mine I would recommend that route. I learned a lot and it didn't really take that long. If you use the stick fuel to the heads get a 3/4" orb to 1/2" pipe thread coupling and reduce it to 3/8" barb. That is the hardest part. I just cleaned my bench. Otherwise I would send a photo.
I think the stock pump could have the hose connection removed and welded to the orb fitting. But that is not exactly screwing some junk together.
Wiring is super simple. Use your fuel bowl heater wire to set a fused (20amp) relay that sends power to the pump through an inertia switch. I used a stock SD pump and Dorman fittings for the pump.
Wix filter bases and filters mounted to an angle bolted to the cross member, from the 95 efuel thread.
I wish I had done it years ago but I didn't.
I think the strictly kit is very good. I basically copied a lot of their design. The steel fittings and pishlock hose is darn affordable. If I were to buy a kit myself it would be strictly kit. Their customer service is stellar as well.
Yeah I'm surprised he is nervous with this project when he did the psd swap into the bronco. Granted, it is a lot easier than you might think it is, but talking to him today about it, it seems he wants to just get something right now, and then put it in and be done with it. He was daily driving it until this issue. He was in the process of prepping his camaro for an engine swap but now thats on hold because he is driving it now. So I am positive he could easily make his own kit, I'm sure even I can and I am nowhere near as experienced as he is here, but I think he's looking for quick. But hey, maybe I will benefit from it because we can build one for me when I get ready to do e fuel on my f250.haha
If I had a $1,000 budget I would absolutely do the efuel. I've collected a few pieces already so I think I could do it for $500.
But if I was on a tight budget, short of needing to replace the filter canister itself, I'd replace whatever needs attention, even the mechanical fuel pump if it needed. I'd add an in-cab fuel pressure gauge and watch the pressure and fret about Efuel if/when the injectors start taxing the stock fuel system.
Yeah I know I would be able to build my own somewhat easily, but I think the extra components I may need (like fittings etc.) aren't available nearby to me so I'd have to drive on the opposite side of Phoenix probably. I also haven't had much free time recently so I could see the extra running around adding up to weeks to a month or so.
I'm just being a little lazy but also would like to get my truck up and running again as fast as possible since I have a bit of work I'd like to do on my camaro ad well. I have a 350 sitting in the garage that needs to replace the camaros 305, but I can't get that out of the way when my Bronco is down!
I was going to order Beans diesel fuel aystem, but their website said they had potential order delays and I couldn't get a hold of them when I called so I went ahead and ordered the Bar None kit.
Im hoping I can get it by this weekend so I can be back to driving the Bronco! I'll at least start by taking out the fuel bowl/pump/lines so that's done!
Oh, and I did get my gauge working recently. The psi was semi low (about 35 at idle), but the BB mod pushed it up to around 50-60. However, fuel is getting in my oil so I'm assuming that's due to the fuel pump leaking out through the plunger. I don't think fuel would really enter the crankcase any other way.
This is exactly what I found doing research. My first kit was a stellar one built by Bill. In the 4 years I had it, it NEVER gave me issue and was really simple to install. My second one is coming this week. It's a used kit done by Dieselsite that gave its first owner zero issues.
