Stalling at high RPMs
Old Jan 18, 2017 | 09:02 PM
  #61
rpau5588's Avatar
rpau5588
Originally Posted by 87crewdually
With the IPR maxed out you may have a gross leak. Pop the hood let it cool.
Pump could be going out.
What's ICP Key On Engine Off?
Icp 0
ipr 15
Old Jan 18, 2017 | 09:03 PM
  #62
rpau5588's Avatar
rpau5588
Originally Posted by rpau5588
Icp 0
ipr 15
Right now it says my eot 175
Old Jan 18, 2017 | 09:11 PM
  #63
87crewdually's Avatar
87crewdually
Did it stall again @ highway speeds or around town? Don't kill your Batts trying to start it. Let it cool down in hopes it will start once cooled so you can get it home.
Re-reading your thread the only thing left to leak and not build pressure is the pump. As long as you did a thorough test leaving it pressurized with air for a while to check for leaks.
Old Jan 18, 2017 | 09:17 PM
  #64
rpau5588's Avatar
rpau5588
Eot Is still climbing with just the key on 211 now
Old Jan 18, 2017 | 09:18 PM
  #65
87crewdually
What is the coolant Temp?
Old Jan 18, 2017 | 09:35 PM
  #66
rpau5588's Avatar
rpau5588
I don't have coolant set up eot is 258 now tho and I haven't started it yet
Old Jan 18, 2017 | 09:38 PM
  #67
87crewdually
The only way the oil temp is climbing without it running would be if the coolant temp was that high and I doubt it.
Scan Gauge has a preset for coolant temp. Or program it in the Xgauge.
Old Jan 18, 2017 | 09:46 PM
  #68
87crewdually
Also double check xgauge for oil temp.
Old Jan 18, 2017 | 10:18 PM
  #69
rpau5588's Avatar
rpau5588
B
I had the gauge entered wrong. I'm ideling now. Ipr 23.0
Icp 580
eot 171
Flp 12.5
Fmp 47.5
Icv .82
Rpms are at 688 it feels like there is a slight miss
Old Jan 18, 2017 | 10:23 PM
  #70
rpau5588's Avatar
rpau5588
Icp 580
eot 171
Flp 12.5
Fmp 47.5
Icv .82
I can shut it off and it starts right back up every time I can drive around town, but as soon as I get on the highway over 55 it shuts off and won't start till it cools down. On the high way or on the on ramp the icp will hit 3124 getting on it the get on the highway and then a couple minuets later if I try to go 60 65 the icp hits 85 and the truck shuts down
Old Jan 18, 2017 | 10:29 PM
  #71
87crewdually
Now that you got the right xgauge codes, what is the oil and water temp at the time it quits or you feel it stumble?
You need to duplicate that temp close to your work area and when it acts up immediately do an air test. Leave the air pressure hooked up for at least 2 minutes. You won't always hear a leak immediately because the air has to push the oil out first, THEN you will hear air leak. Remember the IPR needs to be activated closed when doing this.
Old Jan 18, 2017 | 10:34 PM
  #72
rpau5588's Avatar
rpau5588
I'm done for tonight my problem is I live in Orlando Florida and I'm working in Miami Florida and that's where I'm stuck at with this truck so I can only work on it after working for a couple hours at a time so what I'll do tomorrow is start it get it all nice and hot I'll run a 12-volt feed to the IPR and air test it again and see what I get and I will let you guys know you have a phone number I can get ahold of you at instead of using this thread to talk back and forth
Old Jan 19, 2017 | 01:02 AM
  #73
rpau5588's Avatar
rpau5588
So this truck has me stumped so I'm still at it I figured I would pull the ipr and look at the screen, I pulled it be for I replaced the oil filter stand pipe and the screen was dented and cover with crap, so I changed the screen and this is the new one after the road test is this enough contamination to cause these problems
Old Jan 19, 2017 | 06:24 AM
  #74
WatsonR's Avatar
WatsonR
I would think not. When it starts to die, letting off the throttle save it from a shut down? I think you said it did, just want to be sure.
Old Jan 19, 2017 | 06:32 AM
  #75
rpau5588's Avatar
rpau5588
Usually saves it some times not. If it does save it the next time it happens witch isn't to long after the first time maybe a couple of mineuts, it shuts down
