Hard 1-2 Shift, other problems
3.78 volts in reverse
2.86-2.90 volts from 1st-2nd shift (under normal acceleration)
2.86-2.90 volts from 2nd to 3rd shift (under normal acceleration)
1.90-2.00 volts when I revved the engine to almost 4500 1st to 2nd (shift felt like a rear end).
I managed to get a quick resistance measurement from the EPC solenoid, which came to be 4.5 ohms (cold today so I went quickly). That is within spec from what I read. I figure since we have the resistance and the voltage, you can calculate the current, unless more precise values are needed.
I'm not sure if these values are actually right because I can't find any information online saying if it is bad, but from what I can tell, it's at least working, and the current value goes down as the truck revs harder. The only thing I can think of now is wiring from the VSS.
I would like to add that when the values for voltage changed, they would gradually get lower, and then instantly spike. For example, if I reved the engine to where the voltage was 1.90-2.00 volts, the second it shifted, it would spike all the way to 3.78 volts (not gradually at all). This is a similar symptom the transmission shop noticed when they described that there was a "spike" in a square sin wave coming from the computer, where they identified it to be the TPS, but they were not certain. If I'm correct, the voltage should not spike but should gradually move back to 3.78 volts (quickly but not instantly).
I did a check using the RABS plug to see the resistance from the VSS. I first measured the actual VSS, which gave me a resistance value of 1995 ohms, and then I measured the plug value, which gave me a value of 1887 ohms. I'm not sure if that reasonable, but it seems so. I also measured the volts AC that came off the VSS while driving (using that RABS plug), and it gradually moved from around 0 to 3.5 volts, and continued to rise depending on the speed. It hit 3.5 volts around 30 mph (within spec from what I'm told).
I tried to retrieve codes from the RABS module using the ground connector, but for some reason, no codes would display on the ABS light. I also tried to figure out the VSS wiring that went to the RABS module, but I couldn't figure out which wires they were.
As for the "winding up transmission" issue. It seems that when my truck is about to shift hard, it does wind up very high. There is a particular point when its winding up (just before its about to shift) that adding throttle only seems to make it wind up harder and shift tremendously hard. Only way to stop the bang is to let off the gas quickly.
I did find this peculiar, but if I manually select 1st gear from the shifter and allow my truck to move forward till my desired rpm to shift, then select second or drive, the truck does not hard shift, or bang. Under normal acceleration, the shift cannot be felt, but under high rev (same hold in first, manually move to 2nd) it feels like your thrown forward a little bit, but there is no bang, no hard shift, etc.
My questions are if someone would know how to retrieve the codes from the RABS module. I would like to see whats stored, but the methods online don't seem to work for me.
My other question is what can I do now to track this problem down (excluding codes from the RABS module).
Anyway, after a few times, reverse got a bit harder, and drive got softer (was not lurching forward anymore), but I could hear a sound as if 2 pieces of metal were hitting each other when ever I went into drive (not reverse at all). On some occasions when shifting into reverse, its almost as if the motor is ready to stall. I had a drop 3 times that were at 500 rpm just after shifting to reverse, and then the engine kicked back up to a safe idle area. I've had this before but I never really noticed the issue till now.
Today I checked the codes with the truck on and off. As before, the KOER test produced 225 on the 2nd try, but 111 on the first try. The KOEO test produced new results into the problem. On the first test, I got code 622 (which is not a continuous memory code). Code 622 is Shift Solenoid #2 circuit fault. This code went away after the first try, and did not come back at all. One code is completely stationary, and that is code 626. This code read continuously for 5 separate tests, and this code is the Coast Clutch solenoid circuit fault.
Code 622 seems to relate to my problems, but its strange why it went away after one test. The coast clutch solenoid issue might also lead to something going on.
The MLPS problem was used to scam countless truck owners. This might still be a problem for you. I have seen several that were pinned backwards. There are many different wiring diagrams for this plug. You can't trust which one is right, test it.
Do you have the EVTM? ATSG manual?
I don't know how good this thread is but it has a lot of information:
https://www.ford-trucks.com/forums/9...d-i-found.html
Do your reverse lights work?
My reverse lights do work. Strange thing was when I put it in reverse the first time from park to reverse, my dad did not see any lights. When I went to drive then back to reverse, they all came on. Park to reverse then had them come on. Quite strange, but I don't know what could cause that.
As for some of my symptoms that I described before that may not have been clear, its definitely the transmission slipping. I mainly addressed the problem when I would go from a stationary stop slightly up an incline. The truck would rev up, barely move for a sec then shoot off after a nice little hit. I had to look up the symptoms, and they say little clunks changing gears or strange gear shifts are all symptoms of a slipping transmission, and I believe that to be the case. The 1-2 shift could even be because of the trans slipping, and so its raising line pressure to prevent it (can't be sure on that last statement). What ever is causing the slip, it's in all gears.
Code 626 (Coast Clutch solenoid circuit fault) still remains after 10-15 tests, without going away and coming back, so there is definitely an issue with this solenoid, but the only thing I can think of now is the solenoid is fried or something inside the transmission itself is causing problems, because all the wiring checked out from the transmission side to the connector just below the fuse box.
