Okay then, the diablo Delta chip it is for my 2000 F-150 4.6 L. If I get the three stage chip (stock, 93 octane program for towing, 87 octane for towing), how do I go about ordering it via the phone? Are the towing programs custom? I am new at this so bear with me.
Secondly, I know it comes with instructions but basically, how hard is it to install
Very easy on the F-150. If you can turn a socket set, that's all it takes. Basically you undo a bolt and a clip to remove the computer. Then you clean off a connector, plug in the module and put the computer box back. No electronics knowledge is required. Takes about 20 minutes on the F-150. Hardest part is deciding where you want to mount the switch (I suggest inside the ash-tray).
