Does anyone know how to use this. I'm having trouble interpreting the led flashes? How many times does it give you each code. I would really like to know how to read this thing.
turn the key on, then turn the reader on, it will make a few really fast bleeps, move some valvles, and make some other noises, then it should read out like this
-it will read out all the current codes
-repeat codes
-long pause
-one beep
-long pause
-stored codes
-repeat stored codes
to erase the stored codes, flip the switch on the reader before you
shut off the ignition.
