Hand Held Code Reader
Old Dec 19, 2001 | 12:11 AM
TexasGuy001's Avatar
TexasGuy001
Does anyone know how to use this. I'm having trouble interpreting the led flashes? How many times does it give you each code. I would really like to know how to read this thing.
Old Dec 19, 2001 | 01:54 AM
charlez's Avatar
charlez
ok, this is how I remember it.
turn the key on, then turn the reader on, it will make a few really fast bleeps, move some valvles, and make some other noises, then it should read out like this
-it will read out all the current codes
-repeat codes
-long pause
-one beep
-long pause
-stored codes
-repeat stored codes
to erase the stored codes, flip the switch on the reader before you
shut off the ignition.
Old Dec 19, 2001 | 01:59 AM
TexasGuy001
Thanks for the help
Old Dec 20, 2001 | 10:31 AM
bjoern's Avatar
bjoern
You don't really need a reader for all that. See
http://dalidesign.com/hbook/eectest.html
for both technique and explanation of led code.
Old Dec 20, 2001 | 10:35 AM
bjoern's Avatar
bjoern
