Smoking glow plug relay
Old Jan 12, 2017 | 06:45 PM
paintubturner's Avatar
paintubturner
Put the truck all back together, turn the key on and waited for the wts light, my husband tells me to turn the key off because the black wire with the red stripe was smoking. What is this new problem?
Old Jan 12, 2017 | 11:54 PM
nateairman's Avatar
nateairman
What all was done? I can't remember. Gold fish syndrome
Old Jan 13, 2017 | 06:04 AM
paintubturner
We have put all new glow plugs, wiring harness under valve covers are all new, new complete fuel bowl, new fuel pump, ebpv delete, new batteries, fixed a short to the cig lighter
Old Jan 13, 2017 | 07:59 AM
knottyrope's Avatar
knottyrope
was it the heavy wire or thin one?
Old Jan 13, 2017 | 09:25 AM
paintubturner
The heavy wire
Old Jan 13, 2017 | 10:04 AM
knottyrope's Avatar
knottyrope
It should not smoke unless you have shorted out something or the wire is frayed
need to ohm out the glow plugs at the connecter with it removed and check for 1 ohm, remove the 2 heavy wires going to the GPR and ohm it out and should only have about .250 ohm on each wire to ground.
Old Jan 14, 2017 | 03:16 PM
kd0nfq's Avatar
kd0nfq
remove the wire crimpers from the glow plug relay....
sorry for the smart#$% comment, i did that on my truck, and actually ended up with a small fire and got to rebuild alot of the wiring under the hood. LOL
i agree with everyone else, start looking for a short.
Old Jan 14, 2017 | 04:54 PM
paintubturner
Put on the new glow plug relay today. One of the post's on the old one was broke inside the relay and was jiggly around. Looks like someone cross threaded the nut then tightened it hard and snapped the post!! New relay and no more smoke
Old Jan 14, 2017 | 09:01 PM
kd0nfq's Avatar
kd0nfq
good to hear. glad it was the relay and not a wiring problem. these old brittle wiring harnesses are a pain.
tpolley
Oct 28, 2008 10:17 AM
timcos
Sep 10, 2008 10:57 PM
wentworth
Jul 9, 2007 08:25 PM
kupuni
May 4, 2006 11:06 PM
Scott Fraser
Mar 19, 2005 10:53 PM
