Ford 390 Crankshaft
01-13-2017, 09:01 PM
on
Ford 390 Crankshaft
I am looking to convert my 74 360 to a 390 by changing the crank.
2 questions:
Can this be completed with the crank alone?
Is there a difference between the 2U and 2UA castings? Will either work?
01-13-2017, 09:23 PM
Both cranks are the same, you can use either one. You must also swap to the 390 rods, they're shorter than the 360 rods.
01-13-2017, 09:25 PM
on
Ah makes sense. Sounds like a donor engine may be in order.
01-13-2017, 10:13 PM
Quote:
Originally Posted by
kawasakiklx1
Contact a machine shop or perhaps Survival Motorsports can help you out.
Ford360dude
07-11-2012 10:49 AM
TheTowingCowboy
31
07-03-2010 04:35 PM
ColodadoFordBoys
28
01-23-2009 02:46 PM
kruise
11-07-2002 11:17 AM
xericx
08-03-2002 11:58 PM
