it's a mystery
Old Jan 25, 2017 | 01:08 AM
didij's Avatar
didij
to be honest i didn't check the other ones, i will have to do that on sat, next day off and will let you know . i will also check the valve, and probably have to get a torq ratchet, re check all my vacuum line will let you know, hell it maybe out of gas i noticed that the truck is sitting at an angle and we didn't put much gas into it because it wasn't going anywhere until this is fixed along with registration tabs being expired
Old Jan 25, 2017 | 08:52 AM
pawpaw's Avatar
pawpaw
Originally Posted by didij
sorry for delay pawpaw,
after checking the compression all was fine
I started by loosening the gas cap removed the relays, disconnected the battery and pushed the fuel valve
took off throttle body , then started removing bolts to intake to upper half off after many cuss words at on bolt that wasn't coming loose i decided to loosen the bolts on the fuel rail i had enough room to pull the # 2 injector out, replaced the injector, and re seated them, re tightened down all the bolts and replaced the throttle body, replaced the pcv valve seeing how i broke the other one. I started the truck it bubbled and farted then died, not it won't start at all it'll fire but cut it's self off. am i supposed to purge the line? did i miss something cranked on it can hear fuel pump humming wondering if fuel relay is bad ?
OK, doing the compression check might have answered tomw"s question about where the missing center spark plug electrode went & if it did any damage & was it from #2 cylinder, you never answered that question.
Might be helpful to post up the compression Numbers on Each cylinder.
On the no run, you might try some starting fluid, or propane in the intake manifold & if it'll run ok, then hook up your fuel pressure gauge & do the volume/flow rate test, as that'll purge/burp the fuel rail & tell how the pump & fuel filter are flowing, then the pressure test will tell how robust the fuel pump is & how sound the fittings & injectors are/if they'll hold pressure for a long time after the pump turns off.
didij what are gonna do with you, if you'd just slow down, take a deep breath & review your thread's answers, before jumping into the next phase of your trouble shoot, they might save you some time & frustration.
I know your getting frustrated when a procedure doesn't fix things right away, but the results you get & post up are telling & help us suggest which next step is best to take in solving a problem.
If it'll run on the propane, then you'll know low fuel level & being parked on a slope might be a problem & the pump flow & pressure test would also tattle on that possibility.
Would be helpful to know the resistance of All of the injectors.
Sooner, or later your gonna get er fixed, so keep us posted on how it goes & the forum will stay with it as long as you will.
PRIMERED79 SHORT BED
Dec 30, 2016 08:14 PM
Klindsey1990
3.0L V6
Jan 16, 2013 06:08 PM
whallene
Aug 21, 2011 05:46 PM
budman-mo
Mar 13, 2007 10:22 PM
pike_hunter
Feb 22, 2006 11:08 AM
