Trouble Codes. Help please
Old Jan 10, 2017 | 06:33 PM
Mpollard1990's Avatar
Mpollard1990
1999 f250 with 5.4. Put new head gaskets on it and got it back running. So far I have put new bank one sensor one 02 sensor and new mass air flow. Truck runs good then bogs for a second and straightens up. Current codes are p1142. P0135 and p1151
Old Jan 12, 2017 | 01:17 AM
Pocketlint's Avatar
Pocketlint
A little reading for you and then I would check over some of the items listed in these two links and make sure everything is good with the stuff pertaining to the P1142
P1142 Fuel Restriction Condition
You most likely have a vacuum leak or a dirty or bad MAF.
p0135 02 sensor heater circuit malfunction
https://www.autocodes.com/p0135_ford.html
P1151 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean -
Bank 2
https://www.engine-light-help.com/ox...sor-codes.html
Gametrap
Jan 13, 2019 11:20 AM
Mpollard1990
Jan 16, 2017 01:58 PM
CPFR1924
Aug 23, 2011 02:52 PM
SZAlbNM
Nov 27, 2007 08:38 PM
gnjones
1997 - 2003 F150
Jun 14, 2003 01:44 AM
