Lockable Storage
Old Jan 10, 2017 | 04:02 PM
CBeav's Avatar
CBeav
On a vehicle with sun visors being optional you wonder why a door lock was an upgrade? ;-)
Old Jan 10, 2017 | 05:12 PM
dcavan001's Avatar
dcavan001
One advantage we Merc owners have - all that stuff was included as far as I can tell
Old Jan 10, 2017 | 06:05 PM
bigwin56f100's Avatar
bigwin56f100
Originally Posted by Doc
Here's an idea. Get some thick sheet metal and fabricate a hinged door for the top of the tool tray above the fuel tank (if you still have yours in your truck). You could hinge it on the backside and add a couple of hasps with small locks for the front. No, it won't hold your wife's purse, but at least you could lock up some smaller valuables.
I really like this idea, and you mentioned the wife's purse wouldn't fit. What if the lid was another toolbox mounted on top of the first one only upside down?
Old Jan 10, 2017 | 06:25 PM
ALBUQ F-1's Avatar
ALBUQ F-1
That would work (if it cleared the seat) if you split it in the middle and hinged it there.
Old Jan 10, 2017 | 06:44 PM
tip49's Avatar
tip49
Behind seat storage
I built behind seat storage for small tools, jack, jumper cables behind the cab bench seat out of 1/4" plywood. I mounted 9" speakers at either end for "future". The centre portion has a rounded opening in it so that it is accessible when the bench seat is tilted forward. Overall depth is 6-7 inches, slightly angled back towards the top. I still have the tool tray above that, but no lid.
Old Jan 10, 2017 | 07:24 PM
raytasch's Avatar
raytasch
Believe Nothing
There are many size variations of these. I have two basic safes that attach with locking lanyards. They work well for items I don't want to carry into certain places.
GunVault MicroVault XL Digital Handgun Safe MV1000 37% OFF Coupon Available
Old Jan 10, 2017 | 07:49 PM
Doc's Avatar
Doc
Good idea. If a person had a second tool tray, they could hinge it on the front edge (closest to the seat) and still be able to open it when the seat is leaned forward. Plus, as mentioned, it would give more vertical room. Probably close to 8 inches or more.
Old Jan 10, 2017 | 07:50 PM
Doc's Avatar
Doc
I'd like to see a picture of what you built sometime. Good idea with the thin plywood.
Old Jan 10, 2017 | 07:59 PM
56panelford's Avatar
56panelford
I made storage drawers under my seats, they aren't lockable but could be made too fairly easily. 3 inches deep ,12 inches wide and 24 inches long
Old Jan 10, 2017 | 10:33 PM
tip49's Avatar
tip49
Cab Storage
This is the storage compartment I mentioned in my cab. It's good for jack, jumper cables, and smaller items.
It is constructed of 1/2" plywood ribs covered in 1/4" plywood. The facing has a PVC covering like the back of the cab interior .
Old Jan 10, 2017 | 11:48 PM
dcavan001's Avatar
dcavan001
We still have the gas tank behind the seat and I am tall enough that the seat has to be all the way back, but if there is enough space that I can increase the height of the tool box, and put in some locked drawers under the stock seat that would help, and I think I can do that myself. We carry a fair amount of camera equipment some days, but camera bodies and lenses will lay fairly flat - 5 inches in height would be sufficient for most of those things, and it has the advantage of "out of sight, out of mind."
A small box in the bed for tools (and I noticed the battery cables in one of those photos - required equipment with old cars and trucks) with some extra space for daily stuff might be the best way to go for the rest, with the 8' bed we should still end up with some good space. It would be good to have that in some custom look that fit the period, but that's likely more than I will achieve this year, so something like the pro tech box is more likely.
I am planning to do body work and the wood bed next winter and I like the idea of doing some storage under the bed - that's certainly a good suggestion.
Old Jan 11, 2017 | 09:22 AM
56panelford
How is the sound coming from those speakers, are they muffled at all..?
Old Jan 11, 2017 | 10:53 AM
  #28
tip49's Avatar
tip49
Muffled sound
Speakers are not connected, no sound system in truck as of yet. I also installed two 5" speakers on either side kick panels under dash.
I have replaced all window and door seals, but I still have considerable wind noise at highway speeds.
Old Jan 11, 2017 | 10:54 AM
  #29
EBEAR's Avatar
EBEAR
OK guy's I was saving my absolutely ( as yet to be determined ) genius idea but since the tread is started I might as well get your thoughts . This is a saddle tank from a semi . My plan is to cut the left 2/3 's of the top and hinge it for storage leaving the filler cap area for the battery and tools etc. I will also use the nice brass filler for my gas by taking my new plastic left side under running board tank and moving it to the right running board leaving the fill neck to the inside at the back of the cab and connecting it to the brass filler . Since it is aluminium it should polish nicely
Old Jan 11, 2017 | 11:06 AM
  #30
EBEAR's Avatar
EBEAR
OOPS guess I should include the pic's so you have some idea of what I'm babbling about
