Paint prep guidance
I'm starting prep work on my truck and am wondering what I should do about this. The original paint is burgundy, and the coat under that is the white that you see. How should I go about sanding this smooth? These spots are only on the hood, top of cab, etc. Only places where there's excess sun exposure I'd assume. Should I just sand it or is there a better way? Will I be okay spraying primer over this once it's smooth? Thanks in advance
Don't take it down to bare metal. Only down to bare metal where you need to add filler/fix dents.
Gets some 150 grit on a DA and sand down to the original paint. Yes, remove all of the burgundy. Then, with some 220 grit, sand the base paint thin enough that you can almost see the factory primer through it. (If you sand to bare metal, you will have to spray etching primer, which is expensive, a PITA, and requires a an absolutely perfectly clean and moisture free surface if you want it to adhere properly.) Avoid bare metal when you can. )
This is your optimum base and profile for primer adhesion. Assuming that you've fixed your dents, rust etc. Wipe the hood down thoroughly with prepzol, then a tack rag. you may now lay down your primer sealer. Block sand that smooth to get the waves out, go forth with your filler primer, then paint.
Good paint work takes TONS of time, labor and an eye for detail. There are no shortcuts if you want it to look good.
Good luck
As for paint striper if you don't get ALL OF IT OFF, read in cracks & nooks, it will lift anything that is put on top of it. Only time I would use stripper is if there are so many coats of paint & primer sanding will take for ever and I am doing a full repaint, door jams, etc. and even then there are other ways to take it down to a good base as explained in the below post.
Good luck
Eastwood sells large stripping pads think like 9" or little larger. This will take it down to metal if you want but if you move over the panels fast it will remove the loose & flaking paint then hit it with the DA sander to smooth it out for the sealer/primer cost as above.
Dave ----
https://www.ford-trucks.com/forums/9...paintwork.html
X3 you only need to get down to a good base that the new primer & paint can bite into.
Dave ----
Sand blasting done correctly will not warp panels. We do it quite a bit here at our shop. Also we take most all panels down to bare metal. Yes you need a good etching primer but the best and longest lasting result does cost and takes time.
It isn't a Ford but one we have nearly finished. This was sand blasted entirely. Its a frame off restoration. Due to hail and several coats of paint it required taking every panel down to bare metal. No panels were warped sand blasting. 35 years experience doing this type of work. Never warped a single panel yet.
If that green truck is supposed to be a good example of something, I don't see it.
Any kind of blasting can warp panels. Maybe a shop with experience can set a low volume and low pressure and take their time and have minimal warpage, but you are giving advice to thousands of regular people!
Sand starts rust where it lodges.
I offer our example;
Plastic media, broad sections sanded to reduce warping:
I don't see many people going to this extent. This is overkill for most people. The best way because this is a ford and not a chevy and therefore has enamel paint, is to gently sand by hand to good paint and start there, to avoid damaging the metal surfaces if you aren't sure about it.
Aluminum oxide stripper discs, orbital sanders can warp metal if used too liberally on broad or flat surfaces.
Stripper and acid dipped cars continue to "burn" even after the soda wash in cracks and crevices.
Sand and media blasted cars hide pockets of media that attract moisture and result in rust through, as well as warping panels.
Grinding works, if at low speed/low pressure with the appropriate grit. Even then, you now have an enormous task of ensuring the bare metal is ABSOLUTELY ultra clean, ultra dry with no grinding gouges, and the hassle of using expensive, caustic difficult etching primer.
