Sponsored by: Real Truck
Tranny Fluid Change
Old Aug 27, 2003 | 10:23 AM
rdahl's Avatar
rdahl
Tranny Fluid Change
So here's the deal.
I have 36,000 on my F-250 Diesel 4x4. I don't realy tow but i am going on a long road trip Friday and want to change my tranny fluid. I am wondering two things. Do i have to flush the converter or can i just drop the pan? I have a box of Valvoline Durablend Synthetic with Dexron lll, Mercon, and Mercon V. Will this work? I am running 35"s so i want to avoid any premature tranny problems. Thank you in advance.
Ryan
Old Aug 27, 2003 | 11:21 AM
rdahl's Avatar
rdahl
Tranny Fluid Change
Anyone?
Old Aug 27, 2003 | 11:36 AM
Wheels's Avatar
Wheels
Tranny Fluid Change
Check the "tech articles" link on the right. July 2002.
Old Aug 27, 2003 | 01:46 PM
Madblood's Avatar
Madblood
5th Gear
Tranny Fluid Change
Or do like I did and pay your mechanic $100 and keep your hands/clothes/driveway/seats/hair, etc. clean.
There are a lot of places that can do a complete flush-and-fill cheaper than $100, but the first time you change the fluid, there will be a plastic plug (left-over from assembly) laying in the bottom of the pan, and I don't think I'd want it getting blasted into some other part of the tranny. Also, the magnet in the bottom of the pan will probably have a lot of shavings on it the first time around, and I don't know if the commercial flush-and-fill would blow them into the tranny, flush them completely, or just leave them there.
Old Aug 27, 2003 | 08:03 PM
sevenslats's Avatar
sevenslats
Tranny Fluid Change
Having just recently done this myself, I can add a few pieces of info.
1. Don't take it to the cheapest "flush" place. All they do is stir everything up inside there. They don't even drop the pan unless you REQUEST your filter changed. And the magnet is up inside the pan, not on the end of the drain plug.
2. check your Owner's manual. Mercon/MerconV fluid will damage your tranny. get Mercon fluid.
Old Aug 28, 2003 | 07:00 PM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
Tranny Fluid Change
Just did this myself a couple weeks ago. First, do not use fluid rated for both Mercon and Mercon V or you'll be replacing your transmission in the not too distant future. Only use fluid with a Mercon equivalent rating. If it even mentions Mercon V, stay away from it. I put Mobil 1 Synthetice ATF in my tranny. If your tranny has a port to access the torque converter, drain the fluid from your converter (over half you fluid capacity resides in the converter). I didn't flush out the coolers and lines but still removed just over 16 qts from the 17.7 qt system with just the converter and pan drain. If you can't drain the converter or just don't feel like messing with it, I'd take it to a reputable tranny shop that can do a fluid exchange. My local shop wanted $120 to do the fluid exchange and replace the filter. Fluid was extra. So, I saved $120 by doing it myself. I was doing another mod and some other routine maintenance at the same time, so it wasn't that much of an effort to do the tranny fluid change at the same time.
