Sponsored by: Real Truck
What gives?
Old Jan 9, 2017 | 08:33 PM
erikkloss's Avatar
erikkloss
Sorry for so many post, but this just came to me. You can also have a radiator hose that is collapsing. Squeeze your radiator hoses and make sure they are not soft. Sometimes they can squeeze up and block flow of coolant and then release moments later causing temp fluctuations.
Old Jan 9, 2017 | 08:34 PM
erikc838's Avatar
erikc838
I will check that. Thank you
Old Jan 9, 2017 | 08:37 PM
erikkloss's Avatar
erikkloss
Originally Posted by erikc838
I have run the system with the cap off until the thermostat opens. I have read that sometimes you have to do the same thing with the front end jacked up.
That might not be enough time. On the diesels, you have to take it up on the highway and step on it, and maybe as long as a week or more if you just drive casually (of course you got to keep an eye on your temps and coolant level. This is why it is really best to vacuum fill to save all the grief.
Old Jan 9, 2017 | 08:55 PM
Pocketlint's Avatar
Pocketlint
Originally Posted by Kdr358
Motorcraft thermostat and get a new Oem motorcraft resivor cap too, I'll bet that will cure the issues!
I own a few 5.4's and always use the FoMoCo thermostats and filters, The after market ones can be good but they can also fail. If You did your own coolant change , there is a chance you have some air still in the system, you may be able to go to your local Auto zone and rent their little pump doohickey that will allow you to purge some of the air out of the system.
You definitely want to make sure you have the air out of there.
Old Jan 11, 2017 | 11:00 PM
erikc838's Avatar
erikc838
Motorcraft thermostat in. Truck warmed up to 228 and I shut it down. Then all of the sudden, it opened and it ran fine for a while. Shut it down and went back to work, came home and took it to go pick up the kid from school. Within 15 minutes it was at 228 again with no sign of it opening. Not really sure what's up with this thing. I am still suspicious of air pockets.
Old Jan 12, 2017 | 06:07 AM
FractureCritical's Avatar
FractureCritical
do you ever lose cabin heat in the truck when it starts running hot, or does the heater keep going, even when the temps climb? if you lose heat and the truck runs hot, that's an obstruction in the cooling system like a bat T-stat.
If you don't lose heat, another possibility that you should start considering is that you might have a bad head gasket. A bad head gasket can both introduce air pockets into the system and consume coolant into the combustion chamber. A look at the plugs should be a good first step. If a cylinder or two are leaking, you'll see plugs that look different from the others (from being steam cleaned by the coolant). If you find a goofy plug or two, a compression and/or leak-down test should be step 2.
Old Jan 12, 2017 | 07:19 AM
DavidT.'s Avatar
DavidT.
Check for blown head gasket(s). We have a 5.4 3-valve in our fleet that did the same exact thing. Will be fine at one point then overheat at times, even unloaded. Had the coolant system flushed, water pump, t-stat, etc all done w/OEM parts. Even changed out the cylinder head temperature sensor.
It ended up being bad head gaskets. Replaced the head gaskets and 30k miles later, she's still working hard with no issues.
Old Jan 12, 2017 | 08:55 AM
erikc838's Avatar
erikc838
Here is what happens. With a completely cold engine, as it begins to warm I will start to have heat. It will blow heat like normal up until the time when the coolant should be flowing through the upper hose (but it's not). Then the heat goes cold. IFFFF the coolant is allowed, for whatever reason, to flow through the thermostat and upper hose, the heat returns to normal (hot) and truck will run like normal.
It has been going through fits of a few start ups and everything is fine (I drive it all day) and then it will go through a few times of not being able to get water running through the upper hose.
Old Jan 12, 2017 | 08:56 AM
erikc838's Avatar
erikc838
This is my fear, especially with what I have done so far.
Old Jan 13, 2017 | 10:44 PM
erikc838's Avatar
erikc838
Resolution:
Dropped it off at the shop today.
Pressure check - ok
Block test - ok
Burped out enough air during block test to take a little over 2 gal of coolant - bingo
So that coupled with the almost 1 gal I got out of it yesterday, the system was basically half full. Now the thermostat (Motorcraft 192) is open and cooling by 198* and the truck stays 192* ish. Now I believe my troubles are over.
Old Jan 14, 2017 | 07:33 AM
erikkloss's Avatar
erikkloss
Resolution:
Pressure check - ok
Block test - ok
That is good news. Let us know if anything changes. It is nice to read about positive solutions.
Old Jan 14, 2017 | 07:57 AM
stufarmer's Avatar
stufarmer
Goes to show ya we all need a good burp once in awhile ..
glad to see your dilemma is solved
Old Jan 19, 2017 | 05:37 PM
  #28
erikc838's Avatar
erikc838
SOOO
It needed the burp, but a few days later it is DOING IT AGAIN!
Take it back in they looked at for free for 2 days. Long story short, it developed a #8 misfire. Pulled the plug and it is wet from coolant. The air pockets were caused by the engine pulling in some air. The air was then collecting near the thermostat housing and preventing it from opening.
Now the fun part. I can't seem to find anyone that will fix this for less than $3,000. Is this the going rate now for head gaskets, bolts, labor, coolant, oil, resurfacing the heads etc... Seems excessive. I was hoping for between 1500 and 2k
Old Jan 19, 2017 | 07:56 PM
  #29
T diesel's Avatar
T diesel
Man, that SUCKS!
Old Jan 19, 2017 | 09:27 PM
  #30
erikc838's Avatar
erikc838
Yep. Not really sure how I am going to get it running again.
