grounding wire?
Old Jan 8, 2017 | 03:00 PM
nddragon01's Avatar
nddragon01
grounding wire?
Hi All,
While doing the dreaded spark plug change I noticed what appears to be a grounding wire on the firewall of the passenger side. Mine is fraying pretty bad and I was wondering what this wire is called, where it runs to, and what it controls (I guess also wondering how hard it is to replace).
Thanks!
Old Jan 8, 2017 | 08:18 PM
nddragon01's Avatar
nddragon01
No friends can help me out here?
I think it's the grounding strap from the firewall to the back of the engine block. To replace this wire (or double it up since it's fraying away in the middle and doubt I'll be able to reach behind the engine to disconnect/reconnect new one), could I just run another ground strap from the same firewall location to the passenger side head? I think I read somewhere someone mounted one end to the bolt in the head that holds the transmission fluid tube to the head...
Thanks!
Old Jan 10, 2017 | 08:40 AM
milliesdad's Avatar
milliesdad
Speaking as an old car parts guy, you used to be able to buy ground straps at various lengths. Find a parts store with a counter person that has the patience to look for them.
You are right on the grounding.
Old Jan 10, 2017 | 02:09 PM
SparkyAl's Avatar
SparkyAl
If you start seeing weird symptoms in your dash lights and interior controls, that ground is a possible culprit. Changing it may be a bit of a pain, but highly recommended, and the part probably won't cost more than ~$20 at the dealer.
Tideman
Mar 27, 2017 05:05 PM
crazyrwe
Nov 10, 2012 05:19 PM
john11139
Jul 17, 2011 09:04 AM
daningraham
Nov 6, 2010 10:06 PM
