Hey guys I know this has been covered before but I've read and reread and for some reason the truck still won't start. It's a 1970 f100 originally had a 302 but swapped it out for a 351w. The 351 has a comp cam not sure of the specs was in there when purchased. 1.6 roller rockers. Heads are off a 302. Edelbrock rpm air gap. And a quick fuel 670 carb. Summit billet distributor and a msd 6al box. So it tries to start but backfires a lot. So I thought 180 out right? Nope still backfires a lot. I tried to set it on the compression store the intake stroke. 180 out every witch way and still nothing. Can anyone think of something else it could be or point me to another thread? Thanks.
That's exactly what I did and I was adjusting the distributor and still was just back firing. The previous owner said it was running. I don't know if it was running before the cam was put in or after. For all I know he put a bunch of upgrades in it and couldn't get it to run and that's why he sold it. And to be honest I've never really worked on a Ford motor. I've always done chevy stuff so it seems like it's completely different.
I'm not clear how long ago the 351W was swapped in (?) --recently or, a good while ago? and if it's been a while ago, did the 351W ever run normally up until recently?
It takes air, fuel and spark, in the right amount and in the right timing sequence, for the combustion process to happen. If this engine ever ran normally, go back to the last event that was done to the engine before it no longer ran normally.
If it's never run normally, you'll just have to go through the three requirements for combustion and determine through a process of elimination what is or isn't happening, that's keeping the engine from running correctly --is it getting spark and at the correct timming event? (yes or no). Is it getting fuel and in the correct amount? (carburetor adjustment, yes or no). Are there any air restrictions to the induction into the engine or any vacuum leaks? (yes or no).
Yes everything is backwards from a chevy.
Rotor turns the other way and the #1cyl. is on the passenger side not drivers side. firing order not same.
Tell me about it... but I have never seen this motor run. We did this swap a couple months ago and have been fighting with it since then. Carb is good I know for sure. We are getting spark. And I timed it on the #1 compression stroke. So the only other thing I can think of is something with the cam/valvetrain like the timing chain being off? I'm gonna pull the timing cover and look just be be cautious
In addition to this problem you could have a 1-5-4-2-6-3-7-8 cam firing order cam for a 302. When I had my marine repair shop a customer had his engine rebuilt and the rebuilder installed a 302 standard cam in place of the 351. By the time I figured out the problem the boat owner was dismayed to find out that he now has a 170 hp instead of the 190 hp .
So now you have to observe the valve action as the engine is turned to be sure which cam firing order you have.
I'll have to check that. I assumed theyou were the same. Thanks for the info
I'll have to check that. I assumed they were the same. Thanks for the info
Older 302s and non-H.O. 5.0L engines have the older firing order of 1-5-4-2-6-3-7-8. H.O. 302/5.0L engines have the same firing order as the 351W/5.8L engines; 1-3-7-2-6-5-4-8.
Alright so I did some digging. Pulled the timing cover the marks seen here that align with each other are on the number 6 cylinder TDC I belive. I set the distributor on the compression stroke. How i was told to. It's hard for me to explain cause I'm not really a sbf guy. But I'm sure you guys understand. Is the cam upside down? Or is it just me being crazy?
The marks look correct. Turn the engine to the #1 compression stroke @ Tdc.
Then start turning it by hand and then you wil be able to find out which firing order this cam is. As said before 1234 right bank 5678 left bank, ccw on the distributor. Also check that the marks on the harmonic balancer line up with the marks on the timing cover @ #1. You could have either the wrong or a slipped outer wheel on the balancer.
Keep going, you will find the problem.
Sounds like a fireing order problem. Are you 100% certain you have it correct.
I was 100% sure but now im beginning to question my entire existance. So I'm gonna go back and check another 12 times. Is it at all possible that the cam shaft is upside down though?
